Metal corner drawings January 08, 2016 01:51AM |
Re: Metal corner drawings January 08, 2016 02:36AM |
fma
Hi!
I plan to use metal corners to build my future Delta 3D printer, from robotdigg company.
Unfortunately, they don't provide any top view of there products, which is a little bit strange, as it is mandatory to determine horizontal length profiles.
So, does anyone have top view (as DXF or just image with dimensions) of these products:
[www.robotdigg.com]
[www.robotdigg.com] (for both NEM17 and NEMA23, but I think they are the same)
(I don't know yet which ones I will use).
Thanks,
Re: Metal corner drawings January 08, 2016 03:19AM |
Re: Metal corner drawings January 08, 2016 03:30AM |
fma
Thanks!
I think what is important is the position of the concurrent points of the horizontal arms relative to the center of the vertical arm (upper and lower dimension on the drawing).
Re: Metal corner drawings January 08, 2016 03:40AM |
Re: Metal corner drawings January 08, 2016 03:46AM |
Re: Metal corner drawings January 08, 2016 06:34AM |
dougal1957
OK I will see what I can do it won't be an engineering drawing though as I no longer have facilities to do that so it will be a tracing of one of mine with some dimensions on it and it will be to scale. One thing to note though is that unless they have changed them the holes in all of mine are actually 4mm and not 5 as on there drawings.
Doug
Re: Metal corner drawings January 08, 2016 03:01PM |
Re: Metal corner drawings January 09, 2016 08:41PM |
Re: Metal corner drawings January 09, 2016 09:59PM |
Re: Metal corner drawings January 09, 2016 10:23PM |
xile6
Doesnt anyone know the thickness of the flange part where the bolts go in.
I have some m4 bolts but there short like 8mm.
Re: Metal corner drawings January 10, 2016 03:19AM |
