Re: FLSUN from AliExpres October 10, 2016 08:05AM |
slanwar
FLSUN sent to me a firmware for this machine yesterday, I didn't test yet and I'm not sure if is the same as LVD. Anyway today I tested ABS with this printer using the PEI surface and sticked really good with no glue or any other material, was set 100C for the bed and 240C start then reduced only the extruder temp to 230C. Now a question about the second fan (LVD), is the fan connected to the same fan as the extruder's fan? If it is how do you turn off the fan when printing ABS?
--- looks like an older release of marlin and it is the same, they put on the SD-card which was delivered with the printer
Re: FLSUN from AliExpres October 10, 2016 10:14AM |
Re: FLSUN from AliExpres October 10, 2016 11:00AM |
Re: FLSUN from AliExpres October 12, 2016 04:46PM |
Re: FLSUN from AliExpres October 12, 2016 06:57PM |
Theman
... I can dedicate to the printer (it's currently dedicated to my 3axis cnc). I'll use the of to load the firmware, but I'm hoping I don't need to buy a new pc.
Re: FLSUN from AliExpres October 12, 2016 08:11PM |
Re: FLSUN from AliExpres October 12, 2016 08:19PM |
Re: FLSUN from AliExpres October 12, 2016 08:20PM |
Re: FLSUN from AliExpres October 12, 2016 08:29PM |
Re: FLSUN from AliExpres October 12, 2016 10:38PM |
Re: FLSUN from AliExpres October 12, 2016 11:06PM |
Re: FLSUN from AliExpres October 13, 2016 02:43AM |
Re: FLSUN from AliExpres October 13, 2016 03:04AM |
Re: FLSUN from AliExpres October 14, 2016 08:34AM |
Re: FLSUN from AliExpres October 14, 2016 09:35AM |
Re: FLSUN from AliExpres October 14, 2016 09:36AM |
Re: FLSUN from AliExpres October 14, 2016 05:12PM |
Re: FLSUN from AliExpres October 14, 2016 05:40PM |
Re: FLSUN from AliExpres October 14, 2016 05:43PM |
Re: FLSUN from AliExpres October 14, 2016 06:09PM |
Re: FLSUN from AliExpres October 15, 2016 03:36AM |
Re: FLSUN from AliExpres October 15, 2016 04:38AM |
Re: FLSUN from AliExpres October 15, 2016 05:33AM |
Re: FLSUN from AliExpres October 16, 2016 12:45AM |
Re: FLSUN from AliExpres October 16, 2016 08:28AM |
Re: FLSUN from AliExpres October 16, 2016 09:15AM |
Re: FLSUN from AliExpres October 16, 2016 04:33PM |
Re: FLSUN from AliExpres October 17, 2016 11:30AM |
Theman
While I appreciate your comment. I am trying to tackle each problem individually. Is your steps in order? Wouldn't you level the bed before calibation? I tried tape and glue. Seems to work. I've printed a few parts now. So as far as I'm concerned it works at a useable level right now. So my next concern was flash air. Loading the exact same code that worked off the pc does not work when loaded on sd card. Ideas?
Re: FLSUN from AliExpres October 17, 2016 07:31PM |
Re: FLSUN from AliExpres October 18, 2016 03:18AM |
