Print skewed to the right as Z goes up - Issue Found
June 29, 2016 03:03AM
Thought I would try here first as it is Delta specific I think.
Went to print some light bulb covers today and the print looked like the leaning tower of Piza.
Approximately a 3 degree lean to the +X AND +Y direction as Z goes up. (Edited after printing a cube.)
This was fine yesterday and I have printed multiple 200mm tall items that were vertical.
The last part printed last night was the green fan duct in the bottom photo
Steps taken so far,
Checked all towers square to build plate, worst is the right tower at 89.90, the other two are 90.00
Completely redone calibration.
Checked x and y movement is correct, 100mm is exactly 100mm in both directions.
The only concern is the Z tower belt required tightening and visually looks not right however X/Y movement is correct
Now out of ideas, anyone point me in the right direction.
This is a 24mm cylinder, 30mm high, it is actually round and correctly dimensioned but has a approx 3 degree tilt.
Edited 2 time(s). Last edit at 06/30/2016 11:23PM by aussiephil.
Re: Print skewed to the right as Z goes up
June 29, 2016 12:45PM
Might be loose pulleys on the steppershaft? confused smiley
Is it leaning exactly in X+ direction? Then it would be a combined error of two towers.
If it was along the Y axis, the z-tower stepper would be my best guess.
June 29, 2016 05:52PM
It leans to the right in the x+ direction. I would have expected loose pulleys to reflect in the independent x and y travel measurements.
June 30, 2016 12:39AM
OK A little bit more information....
I printed a square and the near three degrees slope leans towards the +X and +Y corner.
June 30, 2016 03:46AM
What electronics and firmware are you using? If it's RepRapFirmware:
1. Make sure you haven't accidentally enabled orthogonal axis compensation;
2. After or during a print that shows these symptoms, run M122 and check the 'Step errors' field. It should be zero.
Do your stepper motors have flats on the shafts?
June 30, 2016 07:53PM
two possible causes
1) lost motion due to slippage
2) orthogonal error
you can test for 1 by starting your printer and doing a normal calibration and then mark where the nozzle touches the bed and the carraige positions when at XYZ=0, if you can measure the carriage positions accurately.
Then, run a program, doesnt have to use filament, just run the program for a couple of hours
After the program has run go back to XYZ=0, is everything in exactly the same place? if NO then you have a lost motion problem.
RepRapPro Mendel 3 Tricolour
RepRapPro Fisher
-Carbon Arms
-Easy adjust Carriage+effector
-axis stiffness mods
HE3D -600 delta
-Duet 0.8.5
-PanelDue
-DC42 Height probe
-RobotDigg metal components
Simplyfy3D
RS Design Spark CAD
June 30, 2016 11:26PM
dc42
Duet 085 with RRF1.13, this is the machine that's getting the DuetWiFi
1. already checked, nope
2. yep was zero.
Yes shafts have flats
See next post for "feel like an idiot for not checking first" details
June 30, 2016 11:41PM
bgkdavis
two possible causes
2) orthogonal error
No issues with 1 or 2 and it was the completely accurate sizing for x y and z that was throwing me off.
For the record here's what i found once i decided to start pulling the machine apart and hopefully this helps others though i feel dumb for not finding it first.
This is a 1.6M high delta that has been fully enclosed and was fully square and vertical till a few nights ago after a nice -4c overnight low.
Nothing looked different and all the x y z calibration measured correctly included measured moves.
So started to strip the machine down and plumb bob all the vertical elements and that's when I got the shock of the day......
Z tower was essential vertical left/right but was leaning in towards the middle.
X and Y towers however where completely out of whack with the same lean to the right looking from the front.
Seems the entire frame twisted around potentially from differential thermal expansion/contraction values of different materials though why it skewed/twisted in that fashion seems rather bizaar.
The upshot is that a skewed print that is sized correctly directly points to leaning towers on a delta.
Now to loosen all bolts and square things back up.
