Re: Tomas's Kossel XL build log November 19, 2016 04:38PM |
DjDemonD
Looking good, nice looking hot end that Dyze unit. Just ordered a Deltaprintr mini hot end for another project, looking forward to trying that.
Make sure to put something insulating over/around the IR sensor PCB, you've got a great location for it - the magnitude of observed effector tilt should be very low, mine is about this close to my heater block. However with mine if the fan shroud its attached to rotates slightly bringing the IR sensor closer to the heater block (despite silicone cover on the heater block and lots of kapton around the IR sensor) the sensor starts to perform erratically, not triggering etc, causing nozzle crashes.
Re: Tomas's Kossel XL build log November 19, 2016 05:23PM |
Re: Tomas's Kossel XL build log November 29, 2016 05:33AM |
Re: Tomas's Kossel XL build log November 29, 2016 05:47AM |
Re: Tomas's Kossel XL build log November 29, 2016 03:38PM |
Re: Tomas's Kossel XL build log December 04, 2016 01:37PM |
Re: Tomas's Kossel XL build log December 04, 2016 05:54PM |
Re: Tomas's Kossel XL build log December 05, 2016 04:42AM |
DjDemonD
That's a shame. I've got the Deltaprintr mini hot end which I started using yesterday, no jams so far and its very small. Heats up quickly too. No thermistor table for it so had to make my own for Marlin. No documentation either, not really a problem but easier to mess it up if you were a beginner, you know attach the thermistor to the heater output etc....
Re: Tomas's Kossel XL build log December 23, 2016 06:06AM |
Re: Tomas's Kossel XL build log December 23, 2016 07:00PM |
Lykle
For future reference, if you need V-slot profiles etc in Europe, try Ratrig.com
Based in Portugal I think. They supplied me with profiles and seem to be on the ball.
Re: Tomas's Kossel XL build log December 24, 2016 03:56AM |
Re: Tomas's Kossel XL build log January 02, 2017 01:14PM |
Re: Tomas's Kossel XL build log January 03, 2017 05:37AM |
Re: Tomas's Kossel XL build log January 03, 2017 05:54AM |
dougal1957
Ooznest in the UK do all the OpenBuilds extrusions and will even cut to your size if you wish.
www.ooznest.co.uk
HTH
Doug
Re: Tomas's Kossel XL build log January 03, 2017 01:19PM |
DjDemonD
How are you getting on with the hotend now? I had a genuine e3d v6 which jammed 3-4 times, in the end I tried a little oil and no problems since (groundnut oil). Feels wrong but it does seem to work. Mini hotend has been problem free so far, but I haven't put that many hours on it yet.
Re: Tomas's Kossel XL build log April 04, 2017 09:10AM |
Re: Tomas's Kossel XL build log April 05, 2017 05:36AM |
Re: Tomas's Kossel XL build log May 18, 2017 03:08PM |
Re: Tomas's Kossel XL build log May 20, 2017 09:44AM |
Re: Tomas's Kossel XL build log May 20, 2017 01:07PM |
Re: Tomas's Kossel XL build log May 20, 2017 01:57PM |
perolalars
I am really interested of what brand the linkage heads are (if thats the right word for it) at the ends of your carbon fiber rods?
And maybe where you bought them?
Regards
Per
Re: Tomas's Kossel XL build log May 27, 2017 03:19AM |
