Hot Delta Build Log January 30, 2017 08:58AM |
Re: Hot Delta Build Log January 31, 2017 04:24AM |
Re: Hot Delta Build Log February 01, 2017 12:36PM |
Re: Hot Delta Build Log February 02, 2017 11:42AM |
Re: Hot Delta Build Log February 03, 2017 03:59AM |
Re: Hot Delta Build Log February 03, 2017 07:26AM |
Re: Hot Delta Build Log February 04, 2017 03:49AM |
Re: Hot Delta Build Log February 04, 2017 04:09AM |
Re: Hot Delta Build Log February 07, 2017 12:31PM |
Re: Hot Delta Build Log February 08, 2017 09:34AM |
Re: Hot Delta Build Log February 08, 2017 01:16PM |
Re: Hot Delta Build Log February 11, 2017 08:15AM |
Re: Hot Delta Build Log February 11, 2017 01:54PM |
Re: Hot Delta Build Log February 11, 2017 02:55PM |
Lykle
But I am interested in why you let them slide at the top? Why not mount them fixed at the top, where the motor also is and have them sliding in the bottom, away from the complexity of having the motor slide up and down as well?
Lykle
Re: Hot Delta Build Log February 12, 2017 02:02AM |
Re: Hot Delta Build Log February 12, 2017 03:13AM |
Lykle
What is the expanded length difference?
Will this be something that can be absorbed by the flexible coupling at the stepper?
Re: Hot Delta Build Log February 12, 2017 06:10AM |
Re: Hot Delta Build Log February 13, 2017 12:10AM |
Re: Hot Delta Build Log February 13, 2017 03:54AM |
clearlynotstefan
I think ya'll are overthinking the part cooling thing a bit. ....
.... A part at 190-250 getting hit with air at 50 is still cooling. As for cooling the heat-break, I hadn't considered that, but of all the enclosed printers running stock hot-ends, we don't see enough posts to suspect heat-creep issues. I'm 80% of the way enclosing my delta at the moment too, let you know how it goes if I finish first.
Re: Hot Delta Build Log February 13, 2017 11:02AM |
Re: Hot Delta Build Log February 14, 2017 12:05PM |
Re: Hot Delta Build Log February 14, 2017 01:43PM |
Re: Hot Delta Build Log February 15, 2017 01:04PM |
Re: Hot Delta Build Log February 15, 2017 02:49PM |
dougal1957
Easy just reverse the Spindle motor Rotational direction
Re: Hot Delta Build Log February 15, 2017 07:46PM |
Re: Hot Delta Build Log February 27, 2017 04:48AM |
