RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 11, 2017 09:12AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 11, 2017 10:41AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 11, 2017 11:39AM |
nebbian
Looks interesting!
How do you mount linear rails to this? Is this meant for dual linear rails, or wheels?
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 12, 2017 02:18AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 12, 2017 03:22AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 12, 2017 01:11PM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 13, 2017 02:53AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 13, 2017 11:13AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 13, 2017 09:33PM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 14, 2017 09:50AM |
WZ9V
If you don't want to use wheels you would be way better off using 60x40 extrusions instead. That would give you the nice big verticals and proper alignment of the linear rail. The top/bottom plate approach does make for an easy assembly and seems pretty stiff even at the Little Monster's 1.2M height.
If Openbuilds would start making 100x40 C-Beam that would be fun because you could then easily mount the linear rail in the channel.
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 18, 2017 06:03AM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 18, 2017 01:27PM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 20, 2017 08:22PM |
Re: RIP large Kossel and Rostock deltas - C beam Deltas are next big thing May 24, 2017 08:18PM |
simspeed
[attachment 94386 C-BeamDelta3.JPG][attachment 94385 C-BeamDelta2.JPG][attachment 94384 C-BeamDelta.JPG]
Here is a C-Beam Delta design I drew up a year or two ago. This would use 1000mm C-Beams for the verticals and 4040 extrusions for the triangulated top. The base uses 8020 for the base perimeters. The usable bed space is 500mm dia.
