Frustrating calibration issue October 19, 2017 01:02PM |
Re: Frustrating calibration issue October 19, 2017 01:29PM |
Re: Frustrating calibration issue October 19, 2017 03:24PM |
Re: Frustrating calibration issue October 19, 2017 04:45PM |
Re: Frustrating calibration issue October 19, 2017 05:13PM |
Recv: initial Bed ht is 261.587494 mm Recv: center probe: 0.0000 Recv: X-69.2800 Y-40.0000 Z13.7699 Recv: X69.2800 Y-40.0000 Z13.8074 Recv: X0.0000 Y80.0000 Z13.9074 Recv: X0.0000 Y0.0000 Z13.7949 Recv: X69.2800 Y40.0000 Z13.0074 Recv: X-69.2800 Y40.0000 Z13.6449 Recv: X-0.0000 Y-80.0000 Z13.2199 Recv: max delta: 0.762500
Re: Frustrating calibration issue October 20, 2017 03:42AM |
Re: Frustrating calibration issue October 20, 2017 06:17AM |
Re: Frustrating calibration issue October 20, 2017 12:55PM |
Re: Frustrating calibration issue October 20, 2017 01:59PM |
Re: Frustrating calibration issue October 20, 2017 02:55PM |
Re: Frustrating calibration issue October 20, 2017 05:45PM |
Re: Frustrating calibration issue October 21, 2017 05:38AM |
Re: Frustrating calibration issue October 21, 2017 06:34AM |
Re: Frustrating calibration issue October 21, 2017 10:48AM |
Re: Frustrating calibration issue October 21, 2017 11:57AM |
Re: Frustrating calibration issue October 21, 2017 01:07PM |
Re: Frustrating calibration issue October 21, 2017 04:54PM |
# Levelling strategy # Example for the delta calibration strategy leveling-strategy.delta-calibration.enable true # Enable basic delta calibration leveling-strategy.delta-calibration.radius 80 # the probe radius # Example for the delta grid leveling strategy leveling-strategy.delta-grid.enable true # Enable grid leveling leveling-strategy.delta-grid.radius 80 # Grid radius in millimeters leveling-strategy.delta-grid.size 11 # Grid size, must be an odd number leveling-strategy.delta-grid.do_home true # Whether to home before calibration leveling-strategy.delta-grid.save true # Whether to automatically save the grid leveling-strategy.delta-grid.initial_height 5 # Height at which to start probling
Re: Frustrating calibration issue October 21, 2017 04:57PM |
Re: Frustrating calibration issue October 21, 2017 05:36PM |
dc42
Can you confirm that the 215.5mm arm length you have measured is between the centres of rotation of the bearings?
Also check that your firmware steps/mm setting matches what you are actually getting from the mechanics. I have heard that unless the belt is under a lot of tension, the pitch of a GT2 belt is in practice slightly less than 2mm.
Re: Frustrating calibration issue October 21, 2017 05:40PM |
Re: Frustrating calibration issue October 22, 2017 04:49AM |
Re: Frustrating calibration issue October 22, 2017 03:28PM |
Recv: Calibrating Endstops: target 0.030000mm, radius 155.000000mm Recv: set trim to X:0.000000 Y:0.000000 Z:0.000000 Recv: initial Bed ht is 480.934326 mm Recv: center probe: -0.0022 Recv: T1-0 Z:4.8831 Recv: T2-0 Z:4.9082 Recv: T3-0 Z:4.9019 Recv: trim already set within required parameters: delta 0.025085 Recv: Calibrating delta radius: target 0.030000, radius 155.000000
Re: Frustrating calibration issue October 26, 2017 07:22PM |
Re: Frustrating calibration issue October 26, 2017 07:29PM |
mikes3ds
What you guys using to plot your height maps. I am thinking about using R, but it seems there are some ones out there already?>
Re: Frustrating calibration issue October 26, 2017 07:40PM |
Re: Frustrating calibration issue October 26, 2017 10:12PM |
Re: Frustrating calibration issue October 27, 2017 03:39AM |
