Kossel xxxl October 23, 2017 06:56AM |
Re: Kossel xxxl October 23, 2017 08:04AM |
Re: Kossel xxxl October 23, 2017 10:12AM |
dc42
Looks good! I'm not sure that you need Nema23 motors for that size printer, but if you do use them, pick ones with a rated current of about 2.5 to 2.8A so that the Duet can drive them directly.
Re: Kossel xxxl October 23, 2017 02:45PM |
Re: Kossel xxxl October 24, 2017 09:52PM |
Re: Kossel xxxl October 25, 2017 03:17AM |
Re: Kossel xxxl October 25, 2017 06:41PM |
Re: Kossel xxxl October 25, 2017 07:52PM |
Re: Kossel xxxl October 25, 2017 08:16PM |
Re: Kossel xxxl October 25, 2017 08:30PM |
number40fan
Go with fire rated drywall. I'd maybe even look into a self releasing fire extinguisher.
Re: Kossel xxxl October 25, 2017 08:36PM |
Milton
maybe the paneling they put behind and around stoves? might be cheap, should be fire resistant. the main issue with fire is the spool igniting, maybe make that in a fireproof box and the rest fairly fire resistant. if you can keep the spool igniting it is a factor of print size. if the spool ignites its a much larger fuel source. I am not sure how much you want to worry about it, but then having a system that removes later worry during long prints is awesome goal. I think a narrow metal tube will cutoff the oxygen and quench a burning strand of filament, needs testing but it seems resonable that a section of 3mm ID brass tube would stop fire advancing along filament. bent and polished it would be low friction, it would lead into a fireproof box for the filament.
Re: Kossel xxxl November 04, 2017 07:50PM |
Re: Kossel xxxl November 08, 2017 01:07AM |
Re: Kossel xxxl November 13, 2017 09:19PM |
Re: Kossel xxxl November 15, 2017 02:01AM |
Re: Kossel xxxl December 11, 2017 10:08PM |
Re: Kossel xxxl December 12, 2017 02:48AM |
Re: Kossel xxxl December 12, 2017 05:03AM |
o_lampe
No chance to use a longer screw so it's supported from both sides?
Re: Kossel xxxl December 12, 2017 01:03PM |
Re: Kossel xxxl December 13, 2017 12:23AM |
Thenewguy
I had the endstop brackets and 4 of these 2020 rail alignment peices sls printed.
[attachment 100404 IMG_5427.jpg]
[attachment 100405 IMG_5426.jpg]
[attachment 100406 IMG_5425.jpg]
This is the best way to mount 9mm that I could come up with. I tried a few methods and even had toothed. This way had less belt wobble for me.
[attachment 100407 IMG_5423.jpg]
[attachment 100408 IMG_5424.jpg]
[attachment 100409 IMG_5429.jpg]
Re: Kossel xxxl December 13, 2017 02:10AM |
Re: Kossel xxxl December 13, 2017 02:51AM |
Re: Kossel xxxl December 13, 2017 09:40PM |
Re: Kossel xxxl December 13, 2017 09:49PM |
Re: Kossel xxxl December 20, 2017 09:50PM |
Re: Kossel xxxl February 12, 2018 03:28AM |
Re: Kossel xxxl February 12, 2018 03:54AM |
Re: Kossel xxxl February 12, 2018 04:05AM |
Re: Kossel xxxl February 13, 2018 03:00AM |
Re: Kossel xxxl February 15, 2018 09:33PM |
