Re: compact carrier for Kossel Deltas November 22, 2017 05:12AM |
Re: compact carrier for Kossel Deltas November 22, 2017 12:09PM |
Re: compact carrier for Kossel Deltas November 22, 2017 05:15PM |
DjDemonD
One of the 4 screw holes in the linear rail carriage now sports a 25mm M3 screw, which both sides of my belt are fixed to, with a twist for the top pulleys, so that as DC said the tension is carried by the belt
Re: compact carrier for Kossel Deltas November 22, 2017 05:31PM |
Re: compact carrier for Kossel Deltas November 22, 2017 05:45PM |
Re: compact carrier for Kossel Deltas November 22, 2017 05:48PM |
Re: compact carrier for Kossel Deltas November 23, 2017 02:43AM |
Re: compact carrier for Kossel Deltas November 23, 2017 02:49AM |
hercek
Flexural modulus of ABS is about 2.25 GPa. Aluminium has it at 68 GPa.
The ability to resist deflection grows with the third power of thickness.
If there is enough space so that you can make your ABS part about 3.3 times thicker (compared to the aluminum original) then it will have the same ability to resist bending. Maybe make it about 4.1 times thicker since 3D printed ABS will we weaker than injection molded ABS.
Flexural modulus of PLA is about 4 GPa. If you print in PLA it should be enough to make it 2.6 - 3.3 times thicker than the aluminum original.
Just some rough numbers
Re: compact carrier for Kossel Deltas November 23, 2017 04:55AM |
Re: compact carrier for Kossel Deltas November 23, 2017 02:10PM |
Re: compact carrier for Kossel Deltas November 27, 2017 03:05AM |
By reading the headline again, I got a crazy idea: Why not built a smaller plugin delta inside the big delta?
Say, you have a big delta with dual shaft steppers and the bed is removable.
Wouldn't it be nice to use the rear stepper shaft to drive a smaller Delta with it? ( given, that the smaller Delta is more accurate than the big one )
You would have to remove the bed, plugin the bottom-less frame of the small delta ( with it's own rods, effector, bed, endstop and hotend ) and go on from there.
Both printers share the bottom frame with electronics and steppers. You just have to design some inner corners to plugin the small towers.
Re: compact carrier for Kossel Deltas November 27, 2017 03:42AM |
Re: compact carrier for Kossel Deltas November 27, 2017 03:50AM |
Re: compact carrier for Kossel Deltas November 27, 2017 07:23AM |
Re: compact carrier for Kossel Deltas December 13, 2017 03:39AM |
Re: compact carrier for Kossel Deltas December 22, 2017 03:45AM |
Re: compact carrier for Kossel Deltas December 22, 2017 04:13AM |
Re: compact carrier for Kossel Deltas December 22, 2017 04:18AM |
Re: compact carrier for Kossel Deltas December 22, 2017 01:44PM |
Re: compact carrier for Kossel Deltas December 22, 2017 03:08PM |
Re: compact carrier for Kossel Deltas December 29, 2017 10:42AM |
Re: compact carrier for Kossel Deltas January 02, 2018 04:00AM |
Re: compact carrier for Kossel Deltas January 02, 2018 04:38AM |
DjDemonD
I will probably get critiqued for this, but with my PCB carriages on my kossel XL, I do not have robotdigg carriages or anything like that on top of them, that's unnecessary complexity and mass. One of the 4 screw holes in the linear rail carriage now sports a 25mm M3 screw, which both sides of my belt are fixed to, with a twist for the top pulleys, so that as DC said the tension is carried by the belt. Ill append an image later.
As for tensioning, I have printed inline tensioners, which work great on deltas as there is so much "spare" belt below the carriages which does not interfere with anything in use that you don't get on corexy's/cartesians, although I'd like to use them there also, as its just one twist of a screw to tension.
[attachment 99816 20171121_22265601.jpg]
Re: compact carrier for Kossel Deltas January 02, 2018 04:48AM |
Re: compact carrier for Kossel Deltas January 02, 2018 07:16AM |
DjDemonD
Well, they were shown with it as a way of holding the belts, but they're quite an expensive belt clip. Still, they sell well.
Re: compact carrier for Kossel Deltas January 02, 2018 08:18AM |
Re: compact carrier for Kossel Deltas January 22, 2018 03:43AM |
Re: compact carrier for Kossel Deltas January 22, 2018 04:36AM |
