Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 29, 2018 05:02PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 29, 2018 05:29PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 30, 2018 03:32AM |
Interested to see your version and to see how reliably it produces equal length rods.
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 30, 2018 05:10AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 30, 2018 12:05PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 30, 2018 12:31PM |
o_lampe
I'd think that excessive resin would disappear in the hollow carbon rod, which is the path of lowest resistance. Maybe it'd help to glue only one side at a time and hang them up, so the resin runs down the rod.
I was surprised about your printed rod -jig, since it must have taken some time and lots of filament.
BTW what did you mean with, you "have the right bearings to measure the length with calipers"?
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 31, 2018 03:28AM |
When Haydn measures these he puts 3/8th inch high-grade ball bearings on each end and measures with calipers, as the end surface of the ball cups is potentially rough and isn't a mating surface, so measuring from those surfaces doesn't really tell you the effective length of each arm.
Re: DemonDeltaTube - A delta inside an acrylic tube... Build January 31, 2018 03:45AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 01, 2018 08:32AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 01, 2018 09:44AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 01, 2018 10:23AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 02, 2018 11:07AM |
o_lampe
I had good results with flexible couplers between leadscrew and stepper shaft. But I added a steel ball ( 4.5mm ) between them. Now the DOF in Z-direction is eliminated and it can only flex in X&Y.
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 02, 2018 01:53PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 03, 2018 02:12AM |
firefly555
o_lampe
Are you saying that by adding a ball bearing inside the coupler (with no gaps to either end), it would eliminate lateral stretch and compression? Compression would be eliminated but I'm not seeing how it would stop the stretching.
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 07, 2018 07:01AM |
M305 P1 X501 R4700 ; heater 1 uses a PT1000 connected to thermistor channel 1 which has a 4.7K series resistor
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 07, 2018 10:45AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 07, 2018 03:45PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 07, 2018 04:27PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 07, 2018 05:36PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 08, 2018 03:37AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 11, 2018 06:59PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 12, 2018 02:57AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 12, 2018 05:24AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 12, 2018 03:48PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 12, 2018 05:53PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 13, 2018 02:42AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 13, 2018 03:29AM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 15, 2018 05:47PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 17, 2018 04:38PM |
Re: DemonDeltaTube - A delta inside an acrylic tube... Build February 18, 2018 03:38AM |
