Re: Haydns printed Mag Rods improved February 28, 2018 08:34AM |
Haydn
Hi MKSA,
I contracted with a machine shop in China to have these ball studs custom made.
They work great in delta printers, because they're inherently zero-backlash.
Re: Haydns printed Mag Rods improved March 14, 2018 06:43AM |
Re: Haydns printed Mag Rods improved March 14, 2018 11:10AM |
Re: Haydns printed Mag Rods improved March 14, 2018 12:59PM |
Re: Haydns printed Mag Rods improved March 17, 2018 12:39AM |
. So I chucked a rod in my drill press, screwed each ball on in turn and sanded the ball smooth... 240 grit, then 600, then 1000, and finally 1000 grit wet. I figure the chrome is non-magnetic, so making it thinner will actually increase the holding force, so I can lose some. The threaded rod allows me to adjust the length of my rods, so I can make them exactly the same (once I set up a jig). With the help of Loktite, they should then stay identical forever.The magnets are (nominally) N52, mounted on the carriages and effector. My slight innovation is to put a 4mm ferrite rod through the hole in the magnet (making sure it is clear of the ball); theory says that this will intensify the magnetic field. These ferrite rods also serve to exactly position and align the magnets on their mounts.
Re: Haydns printed Mag Rods improved March 17, 2018 02:09AM |
frankvdh
However, despite all this, there just doesn't seem to be enough force holding the balls to the magnets. A small protrusion on the top of the print (e.g. a bit of drool or over-extrusion) is enough to break one of the magnetic joints apart. Any thoughts on how to make this work? I've run out of ideas and I'm seriously thinking about going back to Traxxas rod-ends
Re: Haydns printed Mag Rods improved March 17, 2018 07:26PM |
etfrench
frankvdh
Add springs for each arm set between the effector and carriage. Think of the magnets as a convenient way to hold the arms in place while you're installing the springs
Re: Haydns printed Mag Rods improved March 18, 2018 04:19AM |
Re: Haydns printed Mag Rods improved March 18, 2018 04:57AM |
o_lampe
Why not skip the magnet idea and use Delrin balls and springs_only? The weight of the balls&magnets bothered me anyway.
Delrin balls are available as replacement for steel ball bearings. But I haven't seen them with a thread inside, so a drill jig is required.
If there's enough interest in this subject, we better start a new thread.
Re: Haydns printed Mag Rods improved March 19, 2018 05:08AM |
MKSA
Back to standard ball joint in fact. An why Delrin ? What about Igus ?
Re: Haydns printed Mag Rods improved March 19, 2018 06:11AM |
o_lampe
MKSA
You think about Traxxas rod ends or the like? With springs between the rods to eliminate slop?
I meant ballstuds and dished rods, but without magnets. The rods are held in place by a spring/elastic rope running // to the rods from carrier to effector.
The dished part could be as simple as the chamfered edge of the carbon rod. (eg. 10mmOD rod on a 12mm Delrin ball ).
The edge could be covered with epoxy or CA, if it's too abrasive without a coating.
Re: Haydns printed Mag Rods improved March 19, 2018 05:10PM |
Re: Haydns printed Mag Rods improved March 19, 2018 09:39PM |
Haydn
Hi MKSA,
I sell them for $1.50 each.
You can order them directly from me. Postage to Europe is around $14 for a few sets.
In Europe, you might be able to order them from: [www.think3dprint3d.com]
They've got a shipment coming in.
I also build precision arms to work with them. Contact me directly for prices, etc. BTW, Think3dPrint3d usually keeps my 360mm arms in stock, if that length would work well for your printer.
Re: Haydns printed Mag Rods improved March 20, 2018 06:31AM |
No, ferrite would be worse than iron. Relative permeability of ferrite is around 650. Iron has it at 5000. Ferrites are used because of their low losses when magnetic field is changing. But there are no significant magnetic field changes in a delta printer since the speeds are only in the range of 20 cm/s ... which is "nothing".Quote
frankvdh
Ferrite should provide a much stronger attraction than iron?
Re: Haydns printed Mag Rods improved March 21, 2018 08:50PM |
hercek
But really, magnets suck. They are extremely heavy for the forces they can withstand. Get some good ball joints. They are very light and extremely strong. Definitely when compared to magnets.
Re: Haydns printed Mag Rods improved March 22, 2018 03:37AM |
Re: Haydns printed Mag Rods improved March 22, 2018 03:17PM |
Re: Haydns printed Mag Rods improved March 23, 2018 06:20AM |
dc42
I think the ideal would be to use a soft iron pole piece with one end flat for the magnet and the other end concave hemispherical to match the ball stud, with a thin and uniform PTFE coating on either the pole piece or the ball stud. But I don't know how to manufacture that.
Alternatively the pole piece could be concave conical instead of hemispherical.
Re: Haydns printed Mag Rods improved March 23, 2018 08:33AM |
Soft iron housing looks like the best idea. This should completely close the magnetic circuit. It should hold pretty well.Quote
MKSA
A soft iron housing plus a soft iron cup.
Re: Haydns printed Mag Rods improved March 23, 2018 08:55AM |
The cup should obviously not short circuit the mag path, again same as a lifting magnet, just a cup instead of flat, a gap, the outer housing ring that can also be formed to match the ball profile. A thin cup of PTFE between this and the ball that closes the magnetic path.Quote
hercek
MKSA
I would be a bit careful with the soft iron cup part if the housing is already present. The reason is so that the magnetic circuit is not shorted through the cup to the housing (without entering the ball). The goal is to have as much magnetic flux going through the ball as possible.
Re: Haydns printed Mag Rods improved March 23, 2018 07:35PM |
Re: Haydns printed Mag Rods improved March 24, 2018 12:51PM |
gambrose
I have been playing around with FEMM to try and compare different rod magnet designs.
I am no expert but if I understand the results I have been seeing when playing around with different designs then hercek is right in that it can be very hard to get any magnetic flux though the ball when using a iron cup and housing. The majority of the flux will travel though the cup to the edge and jump to the housing skipping the ball.
One design that is simple to increase flux for a countersunk magnet is a small iron core inside the magnet. It is pure theory as I have not validated it but just the conical mag with 8N on the ball with the iron core it when up to 14N. That number is the integral of the Force Via Weighted Stress Tensor on the ball. Which I think represent the holding force on the ball.
Attached to renderings to try and demonstrate what I am talking about. The both have the same scale so you can see the differences in the flux.
Re: Haydns printed Mag Rods improved March 24, 2018 02:07PM |
Re: Haydns printed Mag Rods improved March 24, 2018 04:01PM |
Re: Haydns printed Mag Rods improved March 24, 2018 04:51PM |
hercek
Nice FEMM simulations, but they are not completely correct. They look like the seating/cup for the ball itself acts as the magnet. Try to simulate the situation you drew by hand. It should look better.
Edits in italic.
hercek
Second power of the integral of the magnetic field ( B ) over the ball surface divided by 2μ₀ corresponds to the holding force. Therefore you want to achieve as much magnetic flux going through the ball as possible. Then it will hold best.
Edit: Also note that you want most of the field to enter the ball in the direction of the diagonal rod axe. So that the forces cancel out as little as possible when the surface integral over the ball surface is computed. But the best situation from this point of view would mean big ball which would be heavy so there are some force/weight compromises to be made. Well as it is with the size of magnet, housing ...
Edits in italic.
Re: Haydns printed Mag Rods improved March 24, 2018 05:29PM |
Yes, at best, the housing should touch the ball the same way as the cup touches the ball.Quote
gambrose
I think another issue I had was that the steel housing needs to be very close to the ball to at all effective.
Re: Haydns printed Mag Rods improved March 24, 2018 05:48PM |
hercek
Well, you know my opinion: magnetic joints suck compared to proper ball joints. But if you have access to lathe you probably can design and produce something usable at higher speeds too ... after a lot of simulations with FEMM
Re: Haydns printed Mag Rods improved March 24, 2018 05:58PM |
Re: Haydns printed Mag Rods improved March 27, 2018 08:35AM |
gambrose
MKSA you described a "soft iron housing plus a soft iron cup". I understand that to be something like the sketch I uploaded with this post. I found that to be of benefit the housing needed to extend to be very close to the ball to be beneficial.
My profile I uploaded with my first post was intended as an alternative based on counter sunk magnets.
Re: Haydns printed Mag Rods improved March 30, 2018 06:42PM |
