Optimum dimensions for a Delta - what size is yours? January 23, 2018 11:35AM |
Re: optimum dimenensions for a delta January 23, 2018 01:18PM |
Re: optimum dimenensions for a delta January 23, 2018 03:12PM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 03:30AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 04:17AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 09:11AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 09:39AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 09:51AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 10:14AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 10:30AM |
You do not need to. The extreme case gives you result which is not useful.Quote
DjDemonD
I'd disagree, if I plot a 3D graph with width along x, height along y and print volume along z, there should emerge a cluster around the optimum.
I'd prefer to do this mathematically but I'm not how I'd go about it.
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 11:11AM |
Re: Optimum dimensions for a Delta - what size is yours? January 24, 2018 12:05PM |
Re: Optimum dimensions for a Delta - what size is yours? January 25, 2018 03:09AM |
DADIY
Surely lots of data points only gives you the most common sizes or an average, it doesn't mean that its the optimal size.
Re: Optimum dimensions for a Delta - what size is yours? January 25, 2018 03:18AM |
Re: Optimum dimensions for a Delta - what size is yours? January 26, 2018 03:34AM |
Re: Optimum dimensions for a Delta - what size is yours? January 27, 2018 01:29PM |
Re: Optimum dimensions for a Delta - what size is yours? January 28, 2018 02:40AM |
Are you documenting the coffee mug print somewhere? Is it a dvd drive motor you're using? Very curious to know what sort of hotend you plan to use?
