Making PTFE cups for magnetic rods March 06, 2018 08:51AM |
Re: Making PTFE cups for magnetic rods March 06, 2018 02:40PM |
Re: Making PTFE cups for magnetic rods March 06, 2018 04:18PM |
etfrench
Your magnets wont generate enough force to hold the arms with a 2mm gap.
etfrench
Keeping the socket perfectly centered is probably the biggest issue you'll face.
Re: Making PTFE cups for magnetic rods March 07, 2018 02:16AM |
Re: Making PTFE cups for magnetic rods March 07, 2018 03:46AM |
Re: Making PTFE cups for magnetic rods March 07, 2018 04:26AM |
Re: Making PTFE cups for magnetic rods March 07, 2018 04:56AM |
o_lampe
Does your Delta create enough force to push the soft_but_not_fully_molten PTFE in shape?
o_lampe
I'd probably print a mould first, where I can place a punched_out piece of PTFE into.
o_lampe
But I don't think it's worth the trouble, since Delrin is very slippery too and a bit stiffer. It's the No1 choice for selflubricating gears, IMHO.
If IGUS filament wouldn't be so expensive, I'd try printing the cups and then use my smoothing method.
Re: Making PTFE cups for magnetic rods March 07, 2018 10:09AM |
Re: Making PTFE cups for magnetic rods March 07, 2018 10:53AM |
Re: Making PTFE cups for magnetic rods March 07, 2018 11:32AM |
Re: Making PTFE cups for magnetic rods March 07, 2018 03:17PM |
Re: Making PTFE cups for magnetic rods March 07, 2018 03:25PM |
Re: Making PTFE cups for magnetic rods March 08, 2018 12:58AM |
Re: Making PTFE cups for magnetic rods March 08, 2018 03:56AM |
Re: Making PTFE cups for magnetic rods March 09, 2018 03:27AM |
Re: Making PTFE cups for magnetic rods March 09, 2018 04:55AM |
o_lampe
Why not try to put the PTFE sheet between the raw printed cup and the heated ballstud to smooth the printed cup and bond it with the PTFE?
Re: Making PTFE cups for magnetic rods March 09, 2018 02:55PM |
Re: Making PTFE cups for magnetic rods March 10, 2018 02:57AM |
Re: Making PTFE cups for magnetic rods March 11, 2018 06:26PM |
Re: Making PTFE cups for magnetic rods March 12, 2018 08:43AM |
Re: Making PTFE cups for magnetic rods March 12, 2018 09:25AM |
Re: Making PTFE cups for magnetic rods March 15, 2018 05:00AM |
gambrose
MKSA, what did you mean by "Here e=1mm should be enough"?
Re: Making PTFE cups for magnetic rods March 24, 2018 02:56PM |
