Re: Underslung Delta Effector July 22, 2018 08:01AM |
Barracuda72
but about what speeds are we talking?
150mm/s printspeed.. 5000-8000mm/s² accelrations? Magnetic system can easily handle that..
400mm/s print speed? 2G accelerations? Yes..maybe its too much for magnetic rods...but who print so fast on a daily base and not only to test the system limits?
Re: Underslung Delta Effector July 22, 2018 08:23AM |
First layer quality is not a feature of magnetic joints. It is a feature of calibration and z-probe ... which is something different. Yes, your smart effector is supposed to be used with magnetic arms. But one can design smart effector functionality for ball joints and the overall result would be better. It would support higher accelerations.Quote
Barracuda72
I dont want miss it anymore...so much comfort...perfect 1st layer..no matter if i triy a new nozzel..chage from normal hotend to volcano....airbrush nozzle..just hit print and the printer do the rest and give me a perfect layer. for that comfort im willing to have more weight because even now im far away from the limit, this system have.
Re: Underslung Delta Effector July 22, 2018 09:46AM |
Re: Underslung Delta Effector July 22, 2018 02:01PM |
Re: Underslung Delta Effector July 22, 2018 02:58PM |
hercek
Can RepRap FW auto detect towers which are not equidistant and compensate for it?
Or do all the towers need to be tilted in the same direction?
Re: Underslung Delta Effector July 22, 2018 03:07PM |
Re: Underslung Delta Effector July 22, 2018 03:35PM |
2G is about what I would expect with 400 g movable weight and 10N holding force for one rod. I would be interested whether you could get to 3G without disconnection. If you can crank up motor current more and would like to do the test then post the result please. Print quality would be terrible with this acceleration, movable weight and glass based belts but it is still interesting. IIRC you have linear rails so tower flex should not be an issue (it is a problem on traditional rostock with Ø 8 mm smooth rods).Quote
dc42
At 20000mm/sec^2 acceleration the machine sounded much rougher and there were missed steps. I was getting a lot of motor stall warnings, so they might have been caused by insufficient motor torque rather than anything else. Again, no joint detachments. This was on a print with a lot of sharp corners.
Re: Underslung Delta Effector July 22, 2018 05:47PM |
Re: Underslung Delta Effector July 30, 2018 11:29PM |
Re: Underslung Delta Effector July 31, 2018 02:57PM |
Re: Underslung Delta Effector August 01, 2018 12:08AM |
Re: Underslung Delta Effector August 01, 2018 11:40AM |
Re: Underslung Delta Effector August 27, 2018 04:15AM |
This is so true...Quote
nebbian
Either of these slight misalignments will have drastically more effect on accuracy than using ball joints vs Traxxas.
nebbian
No matter how good your measurements are, you will always have a small amount of effector tilt, so an underslung effector will minimise the distortion on printed parts. I've measured this, and is why I went to all the trouble of making many prototypes of underslung effectors before settling on this version.
Re: Underslung Delta Effector May 14, 2019 04:12AM |
Re: Underslung Delta Effector May 15, 2019 02:47AM |
Re: Underslung Delta Effector May 15, 2019 02:04PM |
Re: Underslung Delta Effector May 15, 2019 04:44PM |
Re: Underslung Delta Effector May 15, 2019 04:50PM |
Re: Underslung Delta Effector May 15, 2019 05:03PM |
Re: Underslung Delta Effector May 16, 2019 02:43AM |
Re: Underslung Delta Effector May 16, 2019 06:39PM |
Re: Underslung Delta Effector May 17, 2019 07:51PM |
Re: Underslung Delta Effector May 18, 2019 06:40AM |
Re: Underslung Delta Effector May 18, 2019 09:24AM |
Re: Underslung Delta Effector May 18, 2019 03:24PM |
hercek
[*] dynamic error due to stepper not being precisely at the given microstep position: 24.5 µm
[*] positioning error due to drum length: 4.7 µm
Re: Underslung Delta Effector May 18, 2019 04:16PM |
If you get some time, then print right angle corners at 2 G and about 120 mm/s to show us what kind of ringing will be there. If you think your joints can hold 4 G then try even 4 G and at least 120 mm/s. You may need low layer height so that your extruder can keep up at high speeds and the test part must have huge circumference so that slicer does not slow down the walls because of minimum layer time if infill is zero % (maybe some kind of an outline of a comb shape). But you surely already know that.Quote
dc42
Good magnetic joints work for high speed printing too. My delta using Haydn's mag joints + Duet3D Smart Effector + E3Dv6 hot end will lift more than 1.5kg without disconnecting. The mass of the effector and hot end is about 400g. So I could push it to more than 4G without it disconnecting.
Re: Underslung Delta Effector May 18, 2019 04:33PM |
You can go with smaller drum but there is a limit at the minimum drum diameter of at least abut 2.5 - 3 cm. That is because you cannot bend Ø 1.5 mm steel cable too much. It would break too soon. And to achieve enough torque from the best Nema 17 motors one can buy you need to use low microstepping. Than forces you to use gears to get higher precision. And when you are already forced to use gears then it does not make sense to strive for too small drums. Smaller drums mean higher wear on the cable due to its bending and smaller drums mean higher positioning error due to drum length.Quote
leadinglights
Viewing those two points, surely there would be a better compromise than a 5cm drum?
Specify better what do you mean.Quote
leadinglights
Also, does the error calculation assume that no mitigating measures are taken to optimise the geometry?
It is not about how much force a cable can withstand before it breaks. From this point of view even simple narrow glass core belts are overkill.Quote
leadinglights
Is 1.5mm cable a reasonable choice as even 0.81mm will work comfortably at 100N?
Re: Underslung Delta Effector May 18, 2019 07:19PM |
dc42
Re: Underslung Delta Effector May 20, 2019 02:06PM |
Re: Underslung Delta Effector May 20, 2019 11:04PM |
dc42
