Non Flat printing plane August 31, 2018 12:55PM |
Re: Non Flat printing plane August 31, 2018 04:29PM |
Re: Non Flat printing plane September 01, 2018 02:03AM |
Re: Non Flat printing plane September 02, 2018 08:39PM |
dc42
That's a very common pattern - a crinkled-crisp like appearance, with ridges at one end of the X axis turning into valleys at the other end. It's caused by backlash in the mechanics, and it appears that way because the effector moves in opposite X directions on alternate rows while bed probing.
To fix it:
- Make sure the carriages move freely. With the effector and belts disconnected, they should drop under their own weight without being loose.
- Make sure the joints move freely. I use a little silicone grease on the magnetic joints.
- Make sure the belts are taut.
- Make sure the motor current is high enough, at least 60% of the rated current of the motor.
HTH David
Re: Non Flat printing plane September 03, 2018 06:22AM |
Re: Non Flat printing plane September 04, 2018 10:52AM |
Re: Non Flat printing plane September 05, 2018 06:49AM |
Re: Non Flat printing plane September 05, 2018 01:08PM |
Re: Non Flat printing plane September 06, 2018 02:27AM |
hercek
That may have bad impact on maximum acceleration because he uses magnetic joints.Quote
Redemptioner
Sounds like your next upgrade will be a floating extruder
Re: Non Flat printing plane September 06, 2018 04:51AM |
Re: Non Flat printing plane September 19, 2018 04:24PM |
Re: Non Flat printing plane September 19, 2018 05:27PM |
Re: Non Flat printing plane October 03, 2018 06:16PM |
