plans & parts list for a delta printer January 12, 2021 07:22PM |
Re: plans & parts list for a delta printer January 12, 2021 08:14PM |
Re: plans & parts list for a delta printer January 13, 2021 02:14AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: plans & parts list for a delta printer January 13, 2021 02:38AM |
Re: plans & parts list for a delta printer January 14, 2021 06:50AM |
dc42
The updated version of the second link that Robert posted is [miscsolutions.wordpress.com].
Be warned, delta printers that print accurately need to be built precisely, so they are not cheap to build. However, a good CoreXY build probably costs more.
Re: plans & parts list for a delta printer January 14, 2021 04:15PM |
masterviana
From a while i've been looking to your build as an example for a well desgin delta, the only thing that keeps me from moving forward for a build is the fact of a alu bed. You have machine your 330mm 5mm alu bed. I wouldnt risk that job by myself, creating the holes and "countersunk" the holes.
Re: plans & parts list for a delta printer January 15, 2021 06:52AM |
dc42
masterviana
It's not difficult to drill and countersink three holes in aluminium. I didn't have a drill press at that time so I used a handheld electric drill, a 3mm twist drill bit, and a countersink bit intended for metal.
Re: plans & parts list for a delta printer January 15, 2021 07:26PM |
Re: plans & parts list for a delta printer January 16, 2021 01:58AM |
masterviana
The 3mm holes I think i can deal glue a paper printed whit the holes, the countersink its a bit more harder for me never done that job before. The "countersink" deep its only based on your expirence there is no way to mesure the deep. which countersink bit you've used? Even if dont countersink the holes the print area of the bed its only 300mm and the bed had 330mm, that gives 30mm of margin, if use a 300mm glass i can use the screws without countersink them.??
Re: plans & parts list for a delta printer January 19, 2021 06:59AM |
dc42
masterviana
The point about the glass being larger than the print area is that the clips used to hold the glass in place don't reduce the print area.
I used a standard fluted countersunk bit. At intervals I tested the depth of the countersink, and stopped when the screw head was no longer producing above the aluminium surface.
Another possibility is to use a hexagonal aluminium plate with a round glass bed on top, then the screws could be in the corners of the hexagon and not need to be countersunk.
Re: plans & parts list for a delta printer January 20, 2021 02:49AM |
COUNTERSUNK HOLES. January 23, 2021 02:34PM |
Re: plans & parts list for a delta printer January 23, 2021 02:58PM |
Re: plans & parts list for a delta printer January 24, 2021 02:33PM |
