My little electronics project over Chrismas and New Year January 19, 2021 02:29PM |
Re: My little electronics project over Chrismas and New Year January 26, 2021 07:06PM |
Re: My little electronics project over Chrismas and New Year January 28, 2021 12:33PM |
Re: My little electronics project over Chrismas and New Year January 28, 2021 12:45PM |
Re: My little electronics project over Chrismas and New Year January 28, 2021 02:35PM |
majic79
.................................................................................. For probing, you could sync the query over the serial bus before stepping - might slow things down a bit, but that seems an acceptable price to pay.
Thank you!
Re: My little electronics project over Chrismas and New Year January 28, 2021 04:39PM |
Re: My little electronics project over Chrismas and New Year January 28, 2021 06:49PM |
Re: My little electronics project over Chrismas and New Year January 29, 2021 02:09PM |
Re: My little electronics project over Chrismas and New Year January 29, 2021 03:13PM |
Re: My little electronics project over Chrismas and New Year January 30, 2021 06:25AM |
Re: My little electronics project over Chrismas and New Year January 30, 2021 07:32AM |
Re: My little electronics project over Chrismas and New Year January 30, 2021 07:52AM |
Re: My little electronics project over Chrismas and New Year January 30, 2021 02:25PM |
@leadinglights, for what it's worth I've also been working on an underbed piezo sensor for my delta printer. I noticed that automotive piezo knock sensors use a ring shaped piezo element, with a quite heavy mass glued to them, so they act as more of a seismograph than a microphone. I ground a small flat spot in a 1/2 inch diameter stainless steel ball, and JB-Welded it to the center of a standard Murata 41 mm diameter piezo disc, which feeds a MicroChip 12F1840 ADC input (with very simple clipping and low pass filtering). The results are pretty astounding. It is almost immune to acoustic input (like motor vibration and air horns), but will detect a BB dropping 2 inches onto the bench 4 feet away.Quote
leadinglights
majic79
Thank you!
As long as response times can be in the low millisecond region. I use a probe speed of 2mm per second on my piezo probes which equates to an approach speed of 2 microns per millisecond. At this speed, a 10ms latency would only be 20 microns and fairly reasonable. Having said that, some people seem to use approach speeds for touch sensors in the region of 25mm/second in the belief that piezo and FSR sensors need a good thump. This would give a potential error of 0.25mm
Mike
Re: My little electronics project over Chrismas and New Year January 30, 2021 04:16PM |
Re: My little electronics project over Chrismas and New Year January 31, 2021 01:53PM |
