Can't connect through USB-TTL January 26, 2013 03:55PM |
Sprinter 1.3.22T / 20.08.2012 start Soft PWM Init Planner Init Stepper Timer init Free Ram: 1060 Plan Buffer Size:1152 / 16
Re: Can't connect through USB-TTL January 27, 2013 04:53AM |
But I'm frustrating when I'm trying to connect to the board using Pronterface (either gtkterm, Arduino serial monitor, and so on). Nothing happens. Just `connecting...'
I've given a try to Sprinter, and Pronterface still refusing to connect, but gtkterm shows me, every 3 seconds, the initial message:
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Can't connect through USB-TTL January 27, 2013 05:07AM |
Re: Can't connect through USB-TTL January 27, 2013 07:20AM |
start echo: Brown out Reset Marlin 1.0.0 echo: Last Updated: Jan 27 2013 13:12:13 | Author: (none, default config) Compiled: Jan 27 2013 echo: Free Memory: 1454 PlannerBufferBytes: 1232
100µH Coil result in a brownout reset (was Re: Can't connect through USB-TTL) January 27, 2013 09:10AM |
Re: Can't connect through USB-TTL January 28, 2013 08:00AM |
Is the coil really relevant for other things than the thermistors circuit?
