Gen7 1.5 questions
January 28, 2013 10:02PM
I built Gen7 1.5 and doing checks as described on Gen7 1.4.1 page, there are few possible issues. I want to make sure everything is OK before plugging in ATmega. These are the 'issues':
1. ATmega pin 14 is high. I assume this is OK since it is connected to TX pin of MCP2200.
2. ATmega pin 7 is ~1.1V, is this ok? I thought all the pins should be below 0.5V unless at 5V.
3. All my 5V measure as 5.8V, not sure if it is power supply (using PC power supply) or something else. Is this ok?
I was able to connect the board to my PC using USB, so this seems to be OK. After changing configuration of MCP2200 using config utility, also LEDs (actualy, I could see only 1 since no ATmega plugged in yet) seem to be working.
Thanks,
Erik
Re: Gen7 1.5 questions
January 29, 2013 06:33AM
Honestly, it's a relief to read this. The same worked for me three times without failure, so I released the design, but would it work for everybody? Apparently yes, and I'm happy with it.
That's expected. That's MCP2200's TxD, also ATmegas RxD. Unlike with v1.4 you have signals on the board before inserting the ATmega.
Unless you have a programmer plugged in, pin 7 shouldn't be connected to anything. I'd double check this, but it also could be a static load, especially if these 1.1V dwindle while measuring.
5V Standby in ATX supplies isn't as stable/precise as the main 5V. 5.8V is a bit on the high side, but no surprise here.
January 29, 2013 10:55PM
Even more good news :-) I was able to upload firmware using USB.
I decided to give it a try and it seems to be working fine...
May 11, 2013 01:23PM
Hi there and sorry to pick up this rather old thread, but I've got a question linked to those asked here before...
I'm assembling A Gen7 1.5, too.
After having soldered everything but the Mosfets, I proceeded to the power supply checks.
Everything is how described on this page (http://reprap.org/wiki/Gen7_Board-AVR_1.5), except:
.) Pin 14 of ATmega is at 5V
.) Pin 15 of ATmega is at ~1.1V
I just wanted to ask if that's normal, before blowing up the ATmega.
Thanks in advance.
Regards,
Markus
Edited 1 time(s). Last edit at 05/12/2013 10:04AM by markus3D.
May 12, 2013 09:49AM
Yes, this is normal, because the MCP2200 is already working. You're measuring RxD and TxD of the serial line.
May 12, 2013 10:08AM
Thanks alot.
Soldered the Mosfets, connected the ATmega and lit the whole! ... no smoke until now. smiling smiley
Looking forward to connect the board to PC...
Thanks again.
