Re: Generation 7 Electronics Development October 28, 2011 06:21AM |
#elif MOTHERBOARD == 1 #ifndef __AVR_ATmega644__ #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu. #endifto
#elif MOTHERBOARD == 1 #if defined __AVR_ATmega644__ || defined __AVR_ATmega644P__ #error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu. #endif
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Generation 7 Electronics Development October 28, 2011 07:21AM |
Re: Generation 7 Electronics Development October 28, 2011 07:36AM |
Re: Generation 7 Electronics Development October 28, 2011 08:02AM |
this is odd
#if ! defined __AVR_ATmega644__ && ! defined __AVR_ATmega644P__, but it's always a bit error-prone to suggest something without actually trying it.
Re: Generation 7 Electronics Development October 28, 2011 09:16AM |
Re: Generation 7 Electronics Development October 28, 2011 12:17PM |
Re: Generation 7 Electronics Development October 28, 2011 12:29PM |
Re: Generation 7 Electronics Development October 29, 2011 03:46AM |
will it connect without the opto endstops and all pololus connected to it?
something doesnt work
Re: Generation 7 Electronics Development November 08, 2011 12:24PM |
Re: Generation 7 Electronics Development November 09, 2011 04:16AM |
Re: Generation 7 Electronics Development November 11, 2011 04:02PM |
An unnamed person
got a quick question reference the wiring of my Gen 7 electronics!
I'm just at the stage of connecting my axis endstop switches and just wanted to confirm if the below was correct?
Pin 1 (ATmega) - NC contact on switch
Pin 2 (Ground) - Common on switch
Pin 3 (+5V) - NO contact on switch
Re: Generation 7 Electronics Development November 11, 2011 05:38PM |
Traumflug
Pinout is right, with pin 1 being the one closest
to the interrupter. These comments however ... an
opto endstop isn't a switch. 5V and GND are
static, while pin 1 flips between 4V and 0.2V,
depending on wether the the interrupter is
interrupted or not. 5V doesn't change and you also
can't swap pin2 and pin3, like you could with a
mechanical switch.
Re: Generation 7 Electronics Development November 12, 2011 06:24AM |
So basically a mechanical switch can't be used as an endstop with the Gen 7 Electronics, only Opto endstops!
Re: Generation 7 Electronics Development November 16, 2011 07:25PM |
git
Date: Sat Oct 29 19:56:15 2011 +0200
Board: remove tha ability to feed 5 V through the serial connector.
This is not of much use and had the unfortunate side effect of
destroying the USB-TTL converter while plugging improperly.
Re: Generation 7 Electronics Development November 17, 2011 04:54AM |
Hi, what about users that are connecting their gen7 to standard serial port via max232 based boards? +5V pin in serial connector was best way how to get power for it.
Re: Generation 7 Electronics Development November 17, 2011 07:26AM |
Re: Generation 7 Electronics Development November 18, 2011 05:46AM |
Re: Generation 7 Electronics Development November 18, 2011 01:58PM |
Re: Generation 7 Electronics Development November 19, 2011 05:31AM |
Re: Generation 7 Electronics Development November 19, 2011 05:49AM |
I am using option 1 setup, but I have both "ATX24" and "Serial" jumpers shorted
Re: Generation 7 Electronics Development November 22, 2011 01:00PM |
Re: Generation 7 Electronics Development November 22, 2011 05:00PM |
Re: Generation 7 Electronics Development November 22, 2011 06:38PM |
Re: Generation 7 Electronics Development November 23, 2011 05:28AM |
couldnt get it to run
Re: Generation 7 Electronics Development November 25, 2011 08:08AM |
Re: Generation 7 Electronics Development November 26, 2011 03:56AM |
What`s wrong with current setup?
Re: Generation 7 Electronics Development November 26, 2011 06:28PM |
Re: Generation 7 Electronics Development November 27, 2011 03:40AM |
You have there one 100uF capacitor still connected in circuit while USB spec. allows only 10uF
why to abandon current modularity?
Re: Generation 7 Electronics Development November 28, 2011 05:39PM |
Re: Generation 7 Electronics Development December 03, 2011 03:16PM |
