Re: SCARA Arm Printer
September 24, 2014 09:21AM
how did you managed to solve the problem of backlash?
i have worked on similar project and i come to conclusion that gears are very difficult to be used in high precision machines
September 24, 2014 10:17AM
Springs. There is still plenty of backlash in the gear train, I simply used springs to preload the gear train and pull it all to one side. There are some pictures farther up the thread of the springs used in the other arm configuration. They are torsion springs wrapped around the shaft that pull each arm back. You can see in the videos how well it works printing small cubes, there is no backlash transferred to the print.
[scara3dprinter.wordpress.com]
September 24, 2014 09:09PM
I looked at the phidgets page and the product specs list your gear ratio as 50 4397⁄4913 : 1 ( ~ 50.8949 ). So if you have been using small integer gear ratios like 49 or 51 in your calculations that may cause some calibration issues.
Although they might be calculated, I suspect the numbers listed on the calibration page are measured.
I took a stab at estimating mm per step at a point, it would be interesting to know if the results match up with reality.
The closed form solution for the mm per step looked like it would get ugly, so I took a finite differences approach. I compared the step values at a point and another 0.001mm away in the x and y, but I don't know exactly how much error that introduces.
I saw Mr. Seward's post and he mentioned the calculations taking an atan, square root, some multiplies and adds, but I haven't figured out how to avoid using an arccos as well.
Anyway, hope this helps you in some way.
open | download - morgan.py (4.2 KB)
September 24, 2014 09:26PM
I listed the gear ratio at 49:1 because in this current configuration, I'm using gears to go from the stepper motors to the main shaft. They drop the overall ratio down a bit. I will definitely check out that file and see where I went off the rails.
September 29, 2014 07:18PM
While I'm still working out some bugs for the Morgan configuration, it occured to me that it was possible to make the Armstrong arms in such a way that they can not contact each other during start up. I was not able to implement Saurabh Lanje's end stop code, so will have to wait for the complete firmware to be released. The upper arms were machined in a sort of tear drop configuration.
Now I will focus on getting the Morgan arms up and running.
September 30, 2014 10:33AM
September 30, 2014 12:28PM
Nicely done. Glad to see you are still making progress.
October 11, 2014 04:58PM
I finally got around to building the tensioning spring.
Now to attach the end stops.
October 12, 2014 02:32PM
The bracket for the arm endstops. It will allow the machine to home in roughly the same position used by the standard Morgan setup.
October 15, 2014 01:18PM
October 17, 2014 01:41PM
After more time and effort than any sane person should spend on a task, the end stops are finally working for the Armstrong arms. And it ended up being a fairly simple fix. There was a section in tssalo's marlin_main.cpp section, G28, which he had disabled. I reenabled it, then went to the configuration.h section and set the y axis to home to the negative and the x axis home to the positive. Then in the slicer I added to the custom start G-code:
G28
G92 X0 Y0 Z0
The end result is as can be seen here: End Stop Test
The endstops are adjustable and also swing up and out of the way so that the arms will stow flat, yet won't lose their zero.
October 28, 2014 09:08PM
New, permanent bed leveling mechanism.
December 08, 2014 05:05PM
Once I rebuild the prototype printer again I'm going to try hall effect sensors as endstops.
You can also hide them behind non-magnetic materials, which is nice for aesthetics, which of course made me think of your sleek looking printer.
[notanumber.net]
December 09, 2014 08:53PM
Any pictures or renderings of your progress?
January 24, 2015 06:42PM
I'm toying with the idea of making a small, and thus more light weight SCARA printer. This one would use NEMA 11 stepper motors instead of NEMA 17's.
A rendering next to the arms of the other machine.
This one would have a stationary platform and the arms would move up and down on some Makerslide.
February 24, 2015 11:22PM
Dear Evil Monkey,
Have you decided on a linkage? Are you going with the Morgan type arrangement or something more like the latest renderings? I'm interested in making a SCARA type machine and have gone through a few design iterations, mainly looking at firmware at the moment.
Have you sorted out the firmware? The ancient TTSALO Marlin branch is pretty stale and although the main trunk of Marlin now has support for SCARA kinematics, the documentation is less than comprehensive.
Ultimately I'd like to make a machine very similar to what you're designing.
Thank you!
- Nathan
February 25, 2015 08:53PM
Hi Nathan,
I've settled on the Armstrong type arms. One of the main goals I had when building that machine was compactness and portability. The Armstrong arms stow in a much neater fashion. If you modify Ttsalo's firmware in the manner I described above it will work fine, endstops and all. The only issue is at startup the one arm swings over as can be seen in some of the videos linked above. If I was doing the build over I would make the spacing between the arms wide enough that the arms could not connect when that happens.
As far as I know the main branch of Marlin currently only supports the Morgan type of SCARA. Let me know if you have anymore questions, the world needs more SCARA printers!
November 01, 2015 08:49PM
The Z axis was in need of some repair, so I purchased new bearing blocks and machined up new platform arms. Since the printer is now disassembled, I am going to take this opportunity to redo the sheet metal over the next few days.
November 07, 2015 06:52PM
New assembly next to the old sheet metal.
E3D hot end ready to be modified.
March 17, 2017 10:43AM
Hi, nice design you have there.
I think it will be better if you try to modify wangsamas firmware than marlin for your scara.
there are some features that will make you more easy to make it fit for your scara
1. there are special controls and GCODE to rotate X & Y motor individually, beside move to X & Y direction. G5 X__ Y__
2. there are calibration GCODE tools, G50 that can be used to semi automatic calculate the length of arms, angles and steps per units.
you can find the firmware here [github.com]
and this is the website www.wangsamas.com
