SCARA Arm 3D printer March 16, 2015 07:01AM |
Re: SCARA Arm 3D printer March 23, 2015 03:06PM |
Re: SCARA Arm 3D printer March 23, 2015 03:09PM |
Ambidextrous SCARA September 03, 2016 10:02PM |
vitaminrad
Also, I've discovered that while manual moves are typically clamped, your initial homing offset may be out of bounds so to speak. Make sure after you've homed that you request a G0 move to a valid point.
atan2
with X as the first argument and Y as the second argument, whereas the documentation for this function specifies that the order should be Y, X. Your code ends up producing the right result, but "strictly speaking" the arguments should be swapped and the code that follows adjusted for the differing output. I will be attempting that in my solution, and will post the results.
SCARA_S2 = sqrt(1 - sq(SCARA_C2));
