Greetings!
I am building a wacky little Morgan 3D printer out of spare parts I have and am running into an issue with the z-axis (a little unexpected seeing as the x & y axes calibrated just fine).
When I tell the axis to home, it only travels about ten mm before stopping if not manually triggered on the endstop already (I'm using regular switch endstops). And if I give a motion command to the z, it only ever moves in one direction regardless of the direction I told it to go. And it continues moving until the machine is restarted. Has anyone seen a problem like this before? I looked it up under general Marlin issues but most of those dealt with auto bed leveling, a feature that isn't even in this firmware version.
Attached are my mechanical settings although not a huge amount has been changed in the z-axis yet. I changed some things in eeprom as well if any of that is needed.
Any advice is greatly appreciated.
open |
download -
Morgan Mechanical Settings.txt
(4.3 KB)
