Hi All
i need a help as i build a Polar 3D printer which in the concept seems like R-360 that works on Marline R-360, however my design is a bit different as you see in the attached picture however i have face difficulties configuring the Marlin R-360 although i have experience of Marlin configuration.
I need help and some guidance on what is required to get it configured just make it work as principle and will look for the other possible issues.
I think Marlin R-360 has an issue in case of 360 degree rotation command, and the other point I have used Arduino Ramps 1.3 and ATEMGA 2560 board however the commands never completed and the machine somewhere was stopping on 4th line, i think Arduino is not able to process the commands even they are same of normal Marlin firmware if i am not mistaken, i do not have programming experience.
Z axis planned to be gas or oil cylinder however i did not finalize that as once they are complete will be fixed at the outer circle of the aluminium frame.
I appreciate the reply on my message.
Marlin R-360 link on github:[
github.com]
Regards;
Edited 3 time(s). Last edit at 07/07/2020 02:59PM by Shadi.
