Converted server power supply
Posted by Lsutehall
December 24, 2011 10:35AM
My Prusa is currently using an old (and I think slowly dying) ATX PSU. I had a rummage around work's WEEE skip the other day and came away with an HP ESP113 series server power supply (specifically a PS-3381-1C1). It is rated to 32A at 12V and so ought to provide enough juice for the future heated bed and then some.
I followed a guide I found on an R/C forum to make it work (link here). Putting a meter across the modified supply showed a steady 12.25 volts, so it looks good.
Will try it on my machine when it comes back from it's christmas holidays in the garage.
Just wanted to share as the conversion was fairly easy, there is no need to load up a 5V line for peak output and these PSU's are available on ebay for around £10.
(Photos: 1 2 3 4)
Re: Converted server power supply
December 25, 2011 04:55AM
This varies from PSU to PSU. Some units require a load, others not. Requiring a load is in allowed in the ATX power supply specification, up to 25% wattage on the 5V line are required to get full output on the 12V lines.
January 06, 2012 11:50AM
Great tip! 32A PSU for £9 off ebay - including shipping! smiling smiley
