Re: Tilting 3D Printer for 90 deg overhangs? June 19, 2014 06:51AM |
Re: Tilting 3D Printer for 90 deg overhangs? June 21, 2014 02:13PM |
Re: Tilting 3D Printer for 90 deg overhangs? June 21, 2014 04:24PM |
Re: Tilting 3D Printer for 90 deg overhangs? June 21, 2014 05:23PM |
Re: Tilting 3D Printer for 90 deg overhangs? June 21, 2014 09:18PM |
Re: Tilting 3D Printer for 90 deg overhangs? June 22, 2014 03:03AM |
Re: Tilting 3D Printer for 90 deg overhangs? June 25, 2014 04:32AM |
Thorp
Wonderful work Fabricate!
You have demonstrated value in a 4, 5, or 6 degree of freedom head. More significantly, you have a proof of concept that actually works. You have been able to circumvent the '5DOF slicer problem' in your proof of concept by simply manually writing the gcode. Well done!
Thorp
I have been working on this concept for the last 6 months or so and while my hardware might be a bit more 'refined', my machine sits idle because I don't have the controls setup to drive the machine (note, that my construction is based on the delta design and therefore might not be as 'refined' in your eyes ). I am now working toward a construction that is optimized for the community to be able to be easily reproduced and to then be 'optimized' in the wild.
Thorp
It sounds like there are different camps attacking this problem in different ways. Open source evolution. Wonderful stuff. I only hope that we can continue to support each other and build a community around multi axis printing rather than build walls (and not to imply that I have seen ANY of that here!). To put my money where my mouth is, I plan to 'release' what I have been working on in the coming weeks and get the community involved. I will start here with this thread.
Re: Tilting 3D Printer for 90 deg overhangs? June 25, 2014 04:53AM |
