Adaptive Extrusion Feed March 06, 2014 05:33PM |
Re: Adaptive Extrusion Feed March 06, 2014 07:49PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Adaptive Extrusion Feed March 12, 2014 12:00PM |
Re: Adaptive Extrusion Feed March 12, 2014 02:54PM |
Yep. If you have a known distance between the measuring device and the melt-zone of the hot end, real-time adjusting of extruder feed rate based on the detected diameter and known distance (adding a delay to the adjustment) should be fairly trivial.Quote
Ralf
Sensing the diameter would be the biggest challenge, the rest is just software..
Getting a true volumetric (or cross-sectional area) measurement would make the software side of things easy, as I mentioned.Quote
Ralf
The capacitive approch seems to be the way to go, as this would give you volumetric measurements.
Re: Adaptive Extrusion Feed March 25, 2014 07:15PM |
