running motors in pairs November 15, 2014 04:42PM |
Re: running motors in pairs November 15, 2014 05:18PM |
Re: running motors in pairs November 16, 2014 02:38AM |
Re: running motors in pairs November 16, 2014 09:00AM |
Re: running motors in pairs November 16, 2014 10:43AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: running motors in pairs November 16, 2014 03:45PM |
Re: running motors in pairs November 16, 2014 03:51PM |
Re: running motors in pairs November 16, 2014 04:10PM |
Re: running motors in pairs November 18, 2014 05:02AM |
nophead
You are comparing apples with pears because the NEMA23 is higher voltage and inductance so it will have more torque but be slower. A better comparison would be with a lower voltage NEMA23.
Also the NEMA17 you picked is only 38mm long. A 47mm NEMA17 would have a torque of about 4.2kg.cm for the same current and voltage.
It also depends on what driver you intend to use as that is often the limiting factor rather than the motor.
Re: running motors in pairs November 18, 2014 05:14AM |
Re: running motors in pairs November 18, 2014 05:40AM |
Re: running motors in pairs November 18, 2014 05:52AM |
Re: running motors in pairs November 18, 2014 06:33AM |
Re: running motors in pairs November 18, 2014 07:41AM |
munchit1
so to run through..
the X axis (printer head bars mounts etc total weight) say its 1kg, for ease..
mass would be = 1kg x 9.8 = 9.8
and the accelerasion i presume you choose one just to get started?
so 9.8 x 0.5 m/s/s = 4.9 so the F = 4.9 n
pully (on the motor spindle?) has a radiuos of 5mm i'll asume for the maths its in meters?
4.9n x 0.005m = 0.0245 torque.. in what denominasion?
Re: running motors in pairs November 18, 2014 08:11AM |
Re: running motors in pairs November 18, 2014 08:21AM |
Re: running motors in pairs November 18, 2014 01:04PM |
Re: running motors in pairs November 18, 2014 01:43PM |
