Design Z Axis End Stops Best Practices November 19, 2014 03:16AM |
Re: Design Z Axis End Stops Best Practices May 06, 2015 05:03PM |
Re: Design Z Axis End Stops Best Practices May 06, 2015 05:16PM |
Re: Design Z Axis End Stops Best Practices May 10, 2015 05:05AM |
dc42
On a non-delta printer, if you have a Z-probe (also called a proximity sensor), then you don't need a Z end stop at all.
Re: Design Z Axis End Stops Best Practices May 10, 2015 05:46AM |
o_lampe
dc42
A proximity sensor is a magnet and a hall sensor, right? How would RAMPS/Marlin work with such an analog sensor?
I think, I have some laying around, would be nice to know how to implement it.
Olaf
Re: Design Z Axis End Stops Best Practices May 10, 2015 07:16AM |
Re: Design Z Axis End Stops Best Practices May 10, 2015 09:39AM |
o_lampe
I have a broken thumb throttle from my e-bike laying here.
It sends out a very smooth linear signal ,depending on the distance between magnet and hall sensor.
Wouldn´t it be beneficial, if Marlin would "see the endstop coming" and reduce z-speed during z-home procedure, until a programmed value is matched?
Re: Design Z Axis End Stops Best Practices May 11, 2015 07:03AM |
dc42
RepRapFirmware for Duet electronics does exactly that.
Re: Design Z Axis End Stops Best Practices May 11, 2015 07:35AM |
o_lampe
Wow awesome, but I couldn´t find a hint about z-axis sensors...
