bah, I say, to ATX supplies January 25, 2015 07:54PM |
Re: bah, I say, to ATX supplies January 26, 2015 03:03AM |
Re: bah, I say, to ATX supplies January 26, 2015 01:46PM |
Re: bah, I say, to ATX supplies January 26, 2015 02:09PM |
"No" to cheap LED strip PSUs January 27, 2015 08:51PM |
Hi,Quote
shadowphile
I've gone through 3 supplies now: original I had laying around, a used gamer-grade 750W, and a new 450W. They all died on me shortly after use. My max (steady) current draw is about 16 Amps for the heat bed and one hot-end, plus the motion stuff. The 750W was rated for 60 amps! It still died though, partly I think because I may have accidently shorted the output, although were no sparks or anything.
I finally decided I had wasted $80 trying to save money and instead found a dedicated OEM power supply, same brand I tend to use for designs at work: $50. I'm sure you can find a lower power supply
Mean Well, NES-350-12. Tight regulation of 12V and 30 amp output, more than enough for future expansion. Run all day at full load. No minimum load. Regulated self-cooling fan. Over-voltage, shorted-output, temperature safety circuits. Hard to bust this guy. I opened up the dead 450W supply and its electronix were really cheap and puny compared to the Mean Well, for only a few dollars less and a whole lot of PC cables and connectors I don't want.
[amzn.com]
feedback?
Re: "No" to cheap LED strip PSUs January 27, 2015 10:50PM |
Re: bah, I say, to ATX supplies January 28, 2015 04:06AM |
Re: bah, I say, to ATX supplies January 28, 2015 12:06PM |
Re: bah, I say, to ATX supplies January 28, 2015 04:57PM |
Re: bah, I say, to ATX supplies January 29, 2015 02:59AM |
Re: bah, I say, to ATX supplies January 29, 2015 07:14PM |
dc42
AndrewBCN, I agree with you that good branded ATX PSUs are better for running 3D printers than cheap ATX PSUs. For a while I used a Corsair CX430M in place of the Alpine 550W PSU supplied with my Ormerod kit, even though the Alpine PSU worked OK for me. But I don't understand what you have against 12V OEM power supplies.
dc42
Lots of people are using them. Have you any evidence that they have a high failure rate, or are causing problems for 3D printer owners? You talks a lot about PFC in your wiki page
dc42
, but that is more relevant to the electricity distribution companies than it is to 3D printer owners. Modern 3D printer electronics doesn't need a very well regulated 12V supply - modern boards (not cheap RAMPS clones) are typically tolerant of anything from 12V to 35V - so even if a top-brand ATX PSU might have better 12V regulation than a 12V OEM power supply (which in turn will probably have better regulation than a cheap ATX power supply), this is of little or no consequence.
Unless I am presented with any evidence that 12V OEM power supplies are problematic (and my experience and that of other Ormerod owners is that they are not), I will continue to recommend them to users who are comfortable with doing mains wiring. And I recommend a good modular ATX power supply such as the Corsair CX430M to those who are not.
dc42
One thing you didn't mention in the comparison table on your wiki page is that the 12V OEM power supplies have a voltage adjustment. This is very useful if your heated bed is slightly underpowered.
Re: bah, I say, to ATX supplies January 29, 2015 07:19PM |
anwe79
My main issue with ATX power supplys is that they don't come in 24 volt versions.
The whole system benefits from higher voltages (if designed for it), so I don't consider The ATX route a viable option.
Re: "No" to cheap LED strip PSUs January 29, 2015 07:31PM |
shadowphile
Well I DID ask for feedback!
But I thought I had selected a decent 450W supply because I know that PC supplies can be vastly under-powered compared to their rating (I paid $45 for it). And the 750W was a Corsair.
I'm just used to buying OEM supplies for work (and I use them for general purpose applications and never thought of them as 'LED' drivers; guess that has been a rising consumer application).
I guess we will see how well my power supply lasts.
Re: bah, I say, to ATX supplies January 29, 2015 07:40PM |
dclarkm
ATX supplies usually require both 5V and 3.3V to have some minimal load before GOOD 12V regulation kicks in. The requirement vary widely and the manufacturers would not publish numbers on what is required to run a good, regulated 12V only output (since they don't design the things to be run that way). It's really a crap shoot for the sake of day one savings.
Re: bah, I say, to ATX supplies January 29, 2015 08:52PM |
AndrewBCN
An unnamed, unspecified LED strip PSU, on the other hand, in my opinion is a very, very bad recommendation.
AndrewBCN
Are you aware that the very small regulator on the Arduino is just up to the task of regulating down from 12V to 5V (and actually the RAMPS board has a diode that already brings that down to approx. 11.4V, which is a good thing)? If you raise the voltage of the OEM PSU significantly above 12V you could overload that regulator and get the dreaded smoke coming out of your RepRap electronics.
AndrewBCN
I don't really consider that an advantage or anything that I could recommend that people try. But again, that is my opinion. You can recommend whatever you want and people will do whatever they want. If a heated bed cannot reach 105C with the 12V from an ATX PSU I would rather recommend that people insulate it (see "heatbed insulation" in the wiki) rather than any other hack involving raising the voltage from the PSU. Simpler, safer, and in the end cheaper too. Again, imho.
Re: bah, I say, to ATX supplies January 29, 2015 09:34PM |
dc42
If you go over to the Ormerod forum and look at some of the posts about ABS printing, you will find several people reporting that even with an insulating blanket on top, it takes too long to get the bed to ABS temperature, and the temperature can't be maintained when the blanket is removed to start printing. The option of increasing voltage has been very important to those people. I did get my heatbed up to 110C using an ATX PSU, but it took 20 minutes - which is too long to wait before each print.
Re: bah, I say, to ATX supplies January 30, 2015 12:18PM |
AndrewBCN
That is a rather blanket statement with a big "if". The fact is that at the moment, RepRap electronics are designed for 12V. If you want to use 24V you are pretty much in experimental territory and you'd better know what you are doing. Electricity and smoke often go together in my experience.
Re: bah, I say, to ATX supplies January 30, 2015 12:21PM |
AndrewBCN
As I mentioned above and in the wiki, "Haswell Ready" ATX PSUs (in other words, most PSUs sold nowadays, in January 2015) do not require balancing load resistors, they are designed to provide good 12V regulation with small or negligible loads on the 5V output. Also note that practically all the ATX PSUs sold in the last 5 years or so derive the 3.3V output from the 5V output, so if you need a small load to get good 12V regulation, just providing a load on the 5V output is enough, the 3.3V output can be totally ignored.
Re: bah, I say, to ATX supplies January 30, 2015 01:29PM |
RTurnock
I have an ANTEC 450W power supply, never having done this before, watched a couple of youtube videos, opened the case and started cutting wires off. bundled the yellow 12v and black ground for each rail, to get two 12v 18A circuits, that, in theory could power two 3D printers....
Re: bah, I say, to ATX supplies January 30, 2015 02:25PM |
dc42
RTurnock
Be very careful! I don't know about the Antec in particular, however it may be that the 5Vand 12V negative side connections are internally connected on the power supply PCB. Use a multimeter to check. Also, the cheaper ATX PSUs (again, I don't know about the Antec) have a single voltage regulation feedback loop that feeds a proportion of the 12V rail and a proportion of the 5V rail back to the primary circuit. This will feed back completely the wrong voltage if you separate the 5V and 12V grounds.
Re: bah, I say, to ATX supplies February 04, 2015 06:49PM |
