Elements of 3D printer design March 26, 2015 09:17AM |
Re: Elements of 3D printer design May 14, 2015 01:10PM |
AndrewBCN
- IP licenses: How do I comply with the various licenses of the various elements I am reusing from other designs? Which license should I use to cover my own work?
- Electronics: which controller to use? Does it support all the features I need or plan to use? Where do I put it, how do I hold it to the frame?
- Steppers: how much torque do I need? How do I mount my steppers?
- Wiring: how much wiring do I need? how do I route it? strain reliefs? Colors? connectors? Gauge?
- Heated bed: what size and material? how much power? Can I use the standard MK2 PCB heatbed? How do I level it?
- Availability of standard parts: Do I have to custom machine any parts or have them machined for me on a CNC? How many standard parts can I use?
- Power supply: see Choosing a Power Supply
- Firmware: what are the firmwares supported by the controller I have chosen above, that support all the features I need? Which one to choose? How to configure it?
- Filament path: Where does the spool of filament go? How does the filament reach the print head?
- Costs: this thing is going to end up costing me over $1000, how do I keep costs down?
- Extruder mechanism: choices, choices, choices...
- Hotend: and more choices...
- Cooling: my printer now sure prints fast, but the quality of the prints s...ks and it can't do bridges! Oh, wait, you said "cooling"?
- CAD software: Do I really have to learn OpenSCAD? (yes you do) Bah, no, Google Sketchup is good enough! (no it isn't)
- Ergonomics (while building or while using): Do I put the LCD at the bottom of the printer or somewhere around eye-level? How easy or difficult is it to move around my printer / transport it to a new location?
- Safety (again while building or while using): Will the printer chop off my finger if I accidentally leave it somewhere around the moving print head? Will a laser reflection make me blind? Is there any risk of fire? What about toxic fumes?
- Last but not least, documentation. What 's that? BOM? Plans / Cad drawings / assembly manual / recommended settings? Who needs documentation, I have everything in my mind, anyways...
Re: Elements of 3D printer design May 14, 2015 05:48PM |
Re: Elements of 3D printer design May 15, 2015 05:33PM |
Re: Elements of 3D printer design May 15, 2015 08:19PM |
Re: Elements of 3D printer design May 16, 2015 04:22PM |
Re: Elements of 3D printer design June 07, 2015 06:26PM |
