24V PSU for printer March 31, 2015 11:15PM |
Re: 24V PSU for printer April 01, 2015 01:34AM |
Re: 24V PSU for printer April 01, 2015 06:20AM |
Re: 24V PSU for printer April 01, 2015 11:46AM |
Re: 24V PSU for printer April 02, 2015 03:01AM |
Re: 24V PSU for printer April 02, 2015 03:33AM |
Re: 24V PSU for printer April 02, 2015 07:04AM |
Re: 24V PSU for printer April 02, 2015 05:30PM |
Re: 24V PSU for printer April 02, 2015 08:48PM |
Re: 24V PSU for printer April 02, 2015 11:50PM |
Re: 24V PSU for printer April 03, 2015 08:32AM |
Re: 24V PSU for printer April 03, 2015 05:46PM |
Re: 24V PSU for printer April 06, 2015 05:18PM |
Re: 24V PSU for printer April 06, 2015 09:09PM |
Re: 24V PSU for printer April 07, 2015 02:50AM |
Re: 24V PSU for printer April 24, 2015 03:21AM |
Re: 24V PSU for printer April 24, 2015 05:15AM |
Re: 24V PSU for printer April 24, 2015 06:59AM |
Re: 24V PSU for printer April 24, 2015 07:50AM |
anvoice
It was heatsinked properly. Given that the (underrated) transistor was still rated at 25A, it must have burned out because either it was damaged during shipping (virtually no packaging), or the power transistor was an inferior quality copy.
I wasn't aware on-resistance varied considerably with voltage, good to know. However, comaring the data sheets the max resistances seem to be about the same for both the IRFP4368 and the IRLB3034, so I'm not sure it'd make that big a difference. The only big difference I can find between the two in specs is the Vdss, which is much larger for the IRFP436, I thought that mainly meant it can deal with higher voltages. Their Vgs seems to be the same, so I doubt there's a difference about how they'd be driven. In addition, I'd guess the TO-247 package is a bit more reliable overall due to its intrinsically better power dissipation.
Re: 24V PSU for printer April 24, 2015 07:59AM |
Re: 24V PSU for printer April 24, 2015 08:06AM |
Re: 24V PSU for printer April 24, 2015 08:26AM |
AndrewBCN
Replacing the 24V DC switching power supply with a 0.5KVA transformer is an extremely bad idea, for many reasons.
Re: 24V PSU for printer April 24, 2015 08:40AM |
Re: 24V PSU for printer April 24, 2015 08:47AM |
AndrewBCN
@ dc42
Although I am not 100% certain about this, it would seem the OP is using the RAMPS heatbed output to drive an external circuit with the IRFP4368, and the heatbed output from the RAMPS is likely to be 12V. In other words, he should be fine with the IRFP4368.
Re: 24V PSU for printer April 24, 2015 08:52AM |
dc42
AndrewBCN
@ dc42
If he's driving the mosfet gate directly from the heated bed output, then the PWM will be inverted, i.e. heater at full power when it is supposed to be off.
Re: 24V PSU for printer April 24, 2015 09:23AM |
AndrewBCN
off the top of my head: bulk, weight, cost, no regulation, low efficiency, magnetic losses and consequent heat, hum, 24V AC @ 20A is much more dangerous than 24V DC @ 20A which is already dangerous enough as it is...
Re: 24V PSU for printer April 24, 2015 09:56AM |
Re: 24V PSU for printer April 24, 2015 11:06AM |
Re: 24V PSU for printer April 24, 2015 12:11PM |
Re: 24V PSU for printer April 24, 2015 06:51PM |
