Mini Printer June 12, 2015 09:28PM |
Re: Mini Printer June 12, 2015 09:47PM |
Re: Mini Printer June 12, 2015 09:51PM |
Re: Mini Printer June 13, 2015 03:06AM |
Re: Mini Printer July 08, 2015 03:28AM |
o_lampe
There are certain components that can´t be much smaller/shorter. The hotend with the thermal break made for 1.75mm filament is one of those things.
Sure,you could make your own filament with eg. 0.5mm diameter and use a 0.1mm M3 nozzle but the problems get bigger with smaller parts
A 1.75mm bowden extruder needs a huge or geared stepper. Would it work when scaled down to 0.5mm filament?
I don´t see a benefit of a cute small printer with a PC PSU twice as big...not to mention the electronics
-Olaf
Re: Mini Printer July 08, 2015 03:12PM |
Re: Mini Printer July 09, 2015 07:08AM |
Re: Mini Printer July 09, 2015 07:27AM |
but the topicstarter wants to build a little 3d printer
Re: Mini Printer July 09, 2015 07:52AM |
Re: Mini Printer July 09, 2015 03:32PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: Mini Printer July 10, 2015 04:00AM |
Re: Mini Printer July 10, 2015 09:37AM |
VDX
... 3D-printing is not only related to FDM
Among the first '3D-printers' were LOM-fabbers (LOM=LaminatedObjectManufacturing) - they stacked/laminated sheets of paper or plastic (or ceramic or metal), glued or fused them, cut the contours of the actual slice ... and then started again with laminating, ...
So if you'll see this 'laser-engraver' as basis for a LOM-printer, then this will be valid
Re: Mini Printer July 10, 2015 03:36PM |
o_lampe
Would like to know, how tiny a LOM part could be done.
Re: Mini Printer August 24, 2015 06:28PM |
