hot-end mechanical improvement idea.. July 14, 2015 07:26PM |
Re: hot-end mechanical improvement idea.. July 14, 2015 08:05PM |
Re: hot-end mechanical improvement idea.. July 15, 2015 03:19AM |
Re: hot-end mechanical improvement idea.. July 15, 2015 02:54PM |
Re: hot-end mechanical improvement idea.. July 15, 2015 04:41PM |
Re: hot-end mechanical improvement idea.. July 18, 2015 07:49AM |
That sounds workable to me, as long as you're careful not to over-tighten and drive the heatbreak out. I shall put that on my list of things to try as I was thinking of making a new block anyway.Quote
shadowphile
As for not leaking around the threads inside, the threaded nozzle would
still screw tight against bottom of the (unthreaded) heatbreak.
Re: hot-end mechanical improvement idea.. July 18, 2015 03:07PM |
Re: hot-end mechanical improvement idea.. August 05, 2015 04:44AM |
Re: hot-end mechanical improvement idea.. August 05, 2015 10:02AM |
frankvdh
Just having a pair of flats or a hex machined onto the heatbreak in the space between heatsink and heater block would make it much easier to unscrew the heatbreak from the heatsink.
Re: hot-end mechanical improvement idea.. August 05, 2015 10:22AM |
Admin Registered: 12 years ago Posts: 2,569 |
thetazzbot
frankvdh
supposedly that space is thin for a reason, thats why there are no threads there. the thin metal gap helps block heat travel. thats the theory at least, i dont think it really works in practice because without the fan the heat sink will still get hot as blazes.
Re: hot-end mechanical improvement idea.. August 05, 2015 11:25AM |
