Quoting Zach Hoeken :
> awesome! i should have the production size boards ready for you guys
> to look at tonight after i get off work. hopefully someone can find
> time to go over them and let me know if they're right or not...
> hopefully they will be.
Brilliant! Yes - we're about to make some more Universal boards, so
I'll have a check (it'll be late tonight for me, I guess, so it may
wait till tomorrow...).
I have done a little tidying of the comms and power board (basically
lining the connectors up, making the ground and +12v even fatter, and
adding a logo...). That's in the repository, and I'm about to make one
to test it as I type. (Thereby breaking my own recommendation that we
should test boards _before_ they go in the repository... Sorry; at
least the topology hasn't changed.) I'll make a photographic record of
that for the wiki.
> also, i had another question... on the pcb site, they said that their
> limits are 8mil on traces and spacing, what does that equate to in
> KiCad? i used a size of 25 for the traces on the production board and
> it seemed to work pretty well is that 25mil? i just want to get
> everything lined up and get this thing kicking because i've gotten
> quite a few people emailing me about when the boards will get done.
If you're in inches in kicad the units are mil (thousandths of an
inch); if you're in mm they're in mm. All of our stuff is much wider
than 8 mil so there shouldn't be a problem.
One thing though is getting the drill diameters right for each hole -
they'll need to know that. There must be some sort of industry
standard for this that I don't know, but I found that 0.7 mm (30 mil)
diameter for chip pins, resistor legs and so on is fine, and 0.9 mm (35
mil) is OK for connectors, the 8 chunky diodes on the Universal board,
power transistors, and the pins of the L298N. It may be simplest to
make everything 0.9mm...
The fat capacitor on the comms board needs big holes (1 mm for the ones
I use).
Yours
Adrian
staff.bath.ac.uk]
reprap.org]
_______________________________________________
Developers mailing list
Developers@reprap.org
reprap.org]
