Question about the heated bed. September 16, 2015 04:49PM |
Re: Question about the heated bed. September 17, 2015 10:20AM |
Re: Question about the heated bed. September 17, 2015 11:06AM |
I agree but I do have to say on my boat weight of an i3 rework (reasons I designed my own) the heat went down the black oxide screws and even made my smooth rods hot so I switched to SS and that helped a ton but after 3 or 4 hours the heat still gets to the frog plate (unlike the minutes when I first used the black oxide screws) so SS + an insultator would be best bet I think but I am having a hell of a time finding these things in Metric which is all I deal with.Quote
691175002
Just use stainless fasteners (standoffs/spacers). Stainless is a relatively poor conductor of heat (used in hotend heatbreaks) and quite cheap.
If you want complete overkill you can get ceramic spacers very cheaply: [www.mcmaster.com]
A stainless fasterner through a ceramic flange and unthreaded spacer will have no metal on metal contact and only cost a few bucks.
Suitable plastics are really too expensive to be practical here IMO.
Re: Question about the heated bed. September 17, 2015 02:19PM |
Re: Question about the heated bed. September 17, 2015 03:04PM |
Re: Question about the heated bed. September 17, 2015 04:43PM |
Agreed but wouldn't a plastic screw, or a ceramic screw, be optimal in this situation or can they not handle it the shear stress? Yeah, people love saying springs are sprung but in this instance the bed doesn't move except up and springs make leveling a lot easier but can the threads of a Peek or a Ceramic screw handle Ultimaker springs?Quote
frankvdh
Insulation will slow down the movement of heat, but it doesn't stop it. Stainless transfers heat about 1/4 the speed of normal steel, and epoxies and plastics about 1 millionth. Google "thermal conduction".
To keep something cool, you need to remove the heat faster than it travels through the insulator(s). Try a heat sink of some kind (e.g. a large metal washer) in contact with the screw to conduct heat away from the screw and radiate it to the air.
