Bit Rot
March 25, 2007 10:37AM
That old bug that Vik discovered in the stepper routines that caused
the Y axis to move somewhere but not the X (it only showed up in the
"return to origin while cooling" code) has now spread to disrupt
everything :-(
However, this is not as bad news as it sounds, as at least now I'll
have to fix it properly rather than doing a workround. I have dark
suspicions about the way the sync pulses work combined with the new
Universal board...
Best wishes
Adrian
Dr Adrian Bowyer
[staff.bath.ac.uk]
[reprap.org]
_______________________________________________
Developers mailing list
Developers@reprap.org
[reprap.org]
Re: Bit Rot
March 25, 2007 10:52AM
Wow! Sounds nasty! Good luck chasing the bug(s) that are causing that down.
Re: Bit Rot
March 25, 2007 10:54AM
Dark suspicion confirmed, but it was a simple, if subtle, hardware bug: if you wire the Universal for stepper control it doesn't need the thermistor resistor R3. But one end of R3 also forms a via for the sync pulses...
Given the similarity of the problem to Vik's return-to-zero-for-cooling bug, I'll start looking in the sync code for that too.
Re: Bit Rot
March 25, 2007 05:04PM
so what is the solution? do we leave out R3? we'll need to update
the build instructions.
On 26 Mar 2007 02:54:02 +1200, RepRap Forum Mailer wrote:
> Author: Adrian Bowyer
> Username: Adrian Bowyer (80-45-23-196.static.dsl.as9105.com)
> Subject: Re: Bit Rot
> Forum: Developers
> Link: [forums.reprap.org]
> Approved: Yes
> [reprap.org]
[reprap.org]
Re: Bit Rot
March 25, 2007 06:31PM
Quoting Zach Hoeken :
If you're building an extruder you put R3 in; if you're building a
stepper controller you replace the right-hand end of it with a via. A
commercial board will be through-plated of course, so the problem then
goes away. But for homebrew it's significant.
All the build instructions need to be updated extensively for the new
designs anyhow; I'll have a hack at that in a day or so.
Best wishes
Adrian
Dr Adrian Bowyer
[staff.bath.ac.uk]
[reprap.org]
[reprap.org]
Re: Bit Rot
March 25, 2007 08:13PM
> everything :-(
I must admit to having commented it out here.
Vik :v)
[reprap.org]
