Multi colour printing without wipe or prime towers December 18, 2016 09:50AM |
Re: Multi colour printing without wipe or prime towers December 18, 2016 01:42PM |
Re: Multi colour printing without wipe or prime towers December 18, 2016 03:19PM |
Re: Multi colour printing without wipe or prime towers December 20, 2016 09:31PM |
Re: Multi colour printing without wipe or prime towers January 02, 2017 08:19AM |
Re: Multi colour printing without wipe or prime towers January 02, 2017 09:38AM |
Hubberthus
Wow! I'm completely blown away!
I've never done multicolor printing, and those "bruteforce" wiping towers look bad, so never even tried doing it.
But this, so simple yet does the trick.
Looked around a bit and saw three nice powerful hints around the diamond. My guess: Retract plus standby temperature?
Re: Multi colour printing without wipe or prime towers January 03, 2017 03:22AM |
Admin Registered: 13 years ago Posts: 7,013 |
Re: Multi colour printing without wipe or prime towers January 03, 2017 05:47AM |
Re: Multi colour printing without wipe or prime towers January 03, 2017 06:34AM |
Re: Multi colour printing without wipe or prime towers January 03, 2017 08:38AM |
Re: Multi colour printing without wipe or prime towers January 03, 2017 12:38PM |
Dust
My guess is your simply calculating when the next color is needed and you have worked out how long it takes for a color change to actually start coming out the hotend. You then just switch color ahead of time in the gcode (some tweaks of the gcode are probably needed to get just the right cut location)
This is something I have wanted to try for ages...
Re: Multi colour printing without wipe or prime towers January 04, 2017 03:50AM |
Re: Multi colour printing without wipe or prime towers January 04, 2017 04:38AM |
o_lampe
Have you written a post processing script or do you alter the gcode manually? I'm sure it would only be necessary for the perimeters and only the final layer ( eg, for the flag in the video ) needs to be perfect.
Re: Multi colour printing without wipe or prime towers January 04, 2017 10:09AM |
Re: Multi colour printing without wipe or prime towers January 04, 2017 10:53AM |
o_lampe
What are your plans with this PP-script? Selling it to the highest bidder?
Re: Multi colour printing without wipe or prime towers January 04, 2017 11:27AM |
deckingman
As it stands, the script gets the job done but it ain't pretty and any professional programmer would probably laugh at it (or cry).
Re: Multi colour printing without wipe or prime towers January 04, 2017 02:16PM |
Re: Multi colour printing without wipe or prime towers January 04, 2017 04:38PM |
Re: Multi colour printing without wipe or prime towers January 05, 2017 02:35AM |
dc42
I was so impressed by deckingman's work on this and his results that I intend to add this facility to RepRapFirmware, so that you can print the gcode directly without pre-processing it.
Re: Multi colour printing without wipe or prime towers January 05, 2017 06:35AM |
Re: Multi colour printing without wipe or prime towers January 05, 2017 12:03PM |
Re: Multi colour printing without wipe or prime towers January 06, 2017 04:18PM |
Re: Multi colour printing without wipe or prime towers January 08, 2017 06:00AM |
Re: Multi colour printing without wipe or prime towers January 08, 2017 06:43AM |
drmaestro
Congratulations on the good work. Do you think this could also be used to print with dissolvable supports?
Re: Multi colour printing without wipe or prime towers January 08, 2017 07:08AM |
Re: Multi colour printing without wipe or prime towers January 08, 2017 07:34AM |
Re: Multi colour printing without wipe or prime towers January 10, 2017 10:01AM |
Re: Multi colour printing without wipe or prime towers January 10, 2017 01:01PM |
Frans@France
Thank you!
From what I understand is that it might be worthwhile to investigate the influence of the shape of the "melting chamber" on the result? Could it be that even the entry angle of the filament into the melting chamber has an influence? Like what would happen if that entry is off-center making it whirl more? Just thinking out loud here
Re: Multi colour printing without wipe or prime towers January 16, 2017 12:41PM |
Re: Multi colour printing without wipe or prime towers January 17, 2017 02:56AM |
