Pololu/stepstick compatible stepper drivers without potmeter May 23, 2017 02:45AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter May 23, 2017 07:54AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Pololu/stepstick compatible stepper drivers without potmeter May 23, 2017 08:54AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter May 31, 2017 02:41AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter May 31, 2017 06:25AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter May 31, 2017 01:49PM |
Re: Pololu/stepstick compatible stepper drivers without potmeter May 31, 2017 02:08PM |
Re: Pololu/stepstick compatible stepper drivers without potmeter June 01, 2017 06:42AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter June 02, 2017 02:17AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter June 02, 2017 07:27AM |
Re: Pololu/stepstick compatible stepper drivers without potmeter June 03, 2017 01:50AM |
D_D
The main reason you need to swap those plug-in motor modules is because they are so unreliable. You're never really sure what the current is setting is. Errors in current setting and the poor thermal performance of the board leads to burning up the driver chips. The tiny pots are easily broken. Unless you invest in a ceramic screw driver, it is very easy to short the circuits on the driver board with the screwdriver and kill it.
Re: Pololu/stepstick compatible stepper drivers without potmeter June 03, 2017 02:29AM |
o_lampe
Whatever driver-evolution we will see in the future, the "crappy" plugin controllers will be the first to take advantage of them.
Re: Pololu/stepstick compatible stepper drivers without potmeter June 03, 2017 01:44PM |
Re: Pololu/stepstick compatible stepper drivers without potmeter June 04, 2017 10:05AM |
