RepRap Firmware 1.19 - Custom Axis Homing November 20, 2018 10:58AM |
; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 PArmand ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 M584 X0 Y1 Z2 E3 U4 ; Drive 3 goes forwards M350 Z64 I0 ; Configure microstepping without interpolation M350 X16 Y16 E16 U16 I1 ; Configure microstepping with interpolation M92 X115.4139 Y115.1649 Z458.3991835 E407 U1600 ; Set steps per mm M566 X480 Y480 Z10 E240 U10 ; Set maximum instantaneous speed changes (mm/min) M203 X9000 Y9000 Z600 E1500 U600 ; Set maximum speeds (mm/min) M201 X2000 Y2000 Z100 E500 U100 ; Set accelerations (mm/s^2) M906 X1900 Y1900 Z1900 E1000 U1200 I98 ; Set motor currents (mA) and motor idle factor in per cent M84 S6000 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 U0 S1 ; Set axis minima M208 X380 Y260 Z325 U100 S0 ; Set axis maxima ; Endstops M574 X1 Y1 U1 S0 ; Set active low endstops ; Z-Probe M558 P5 H0 F120 T6000 ; Set Z probe type to switch and the dive height + speeds G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height M556 S150 X1.4 Y0 Z0 ; Set orthogonal axis compensation parameters M557 X15:375 Y15:245 S20 ; Define mesh grid ; Heaters M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S155 ; Set temperature limit for heater 0 to 155C M305 P1 X150 ; Configure thermocouple for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C M141 H3 ; Set heater channel for heated cahmber M305 P3 X151 ;Set thermocouple readout for chamber temperature ; Fans M106 P0 S1 I0 F25000 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F25000 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S1 I0 F25000 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Custom settings are not configured
Re: RepRap Firmware 1.19 - Custom Axis Homing November 20, 2018 03:04PM |
Re: RepRap Firmware 1.19 - Custom Axis Homing November 20, 2018 10:28PM |
Re: RepRap Firmware 1.19 - Custom Axis Homing November 23, 2018 11:46AM |
; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M584 X0 Y1 E2 Z3 U4 ; M350 Z64 I0 ; Configure microstepping without interpolation M350 X16 Y16 E16 U16 I1 ; Configure microstepping with interpolation M92 X115.4139 Y115.1649 Z458.3991835 E407 U1600 ; Set steps per mm M566 X480 Y480 Z10 E240 U10 ; Set maximum instantaneous speed changes (mm/min) M203 X9000 Y9000 Z600 E1500 U600 ; Set maximum speeds (mm/min) M201 X2000 Y2000 Z100 E500 U100 ; Set accelerations (mm/s^2) M906 X1900 Y1900 Z1900 E1000 U1000 I98 ; Set motor currents (mA) and motor idle factor in per cent M84 S6000 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 U0 S1 ; Set axis minima M208 X380 Y260 Z325 U100 S0 ; Set axis maxima ; Endstops M574 X1 Y1 U1 S0 ; Set active low endstops ; Z-Probe M558 P5 H0 F120 T6000 ; Set Z probe type to switch and the dive height + speeds G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height M556 S150 X1.4 Y0 Z0 ; Set orthogonal axis compensation parameters M557 X15:375 Y15:245 S20 ; Define mesh grid ; Heaters M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S155 ; Set temperature limit for heater 0 to 155C M305 P1 X150 ; Configure thermocouple for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C M141 H3 ; Set heater channel for heated cahmber M305 P3 X151 ; Set thermocouple readout for chamber temperature ; Fans M106 P0 S1 I0 F25000 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F25000 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S1 I0 F25000 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools ;;Tool 1 M563 P0 D0 H1 S"WHITE PLA" ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ;;Tool 2 M563 P1 D0 H1 S"BLACK PLA" ; Define tool 1 G10 P0 X0 Y0 Z0 ; Set tool 1 axis offsets G10 P0 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C ;;Tool 3 M563 P2 D0 H1 S"WHITE PETG" ; Define tool 2 G10 P0 X0 Y0 Z0 ; Set tool 2 axis offsets G10 P0 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C ;;Tool 4 M563 P3 D0 H1 S"BLACK PETG" ; Define tool 3 G10 P0 X0 Y0 Z0 ; Set tool 3 axis offsets G10 P0 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C ;;Tool 5 M563 P4 D0 H1 S"PVA SUPPORT" ; Define tool 4 G10 P0 X0 Y0 Z0 ; Set tool 4 axis offsets G10 P0 R0 S0 ; Set initial tool 4 active and standby temperatures to 0C ;;Tool 6 M563 P5 D0 H1 S"CUSTOM MATERIAL" ; Define tool 5 G10 P0 X0 Y0 Z0 ; Set tool 5 axis offsets G10 P0 R0 S0 ; Set initial tool 5 active and standby temperatures to 0C
Re: RepRap Firmware 1.19 - Custom Axis Homing November 23, 2018 12:38PM |
