OptoEndstop 2.1 November 23, 2011 03:21AM |
Re: OptoEndstop 2.1 November 23, 2011 08:33AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: OptoEndstop 2.1 November 23, 2011 03:41PM |
Re: OptoEndstop 2.1 November 24, 2011 06:41AM |
Re: OptoEndstop 2.1 November 25, 2011 02:41AM |
Re: OptoEndstop 2.1 November 25, 2011 04:03AM |
Re: OptoEndstop 2.1 November 25, 2011 09:03AM |
#define MOTHERBOARD 33
Re: OptoEndstop 2.1 November 25, 2011 09:33AM |
windcatcher
In the meantime, do you know what section in the Sprinter file I have to set and how it is supposed to read in order to set Version 2.1 optos correctly?
//// Endstop Settings //#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. //If your axes are only moving in one direction, make sure the endstops are connected properly. //If your axes move in one direction ONLY when the endstops are triggered, set [XYZ]_ENDSTOP_INVERT to true here: const bool X_ENDSTOP_INVERT = true; const bool Y_ENDSTOP_INVERT = true; const bool Z_ENDSTOP_INVERT = true;
Re: OptoEndstop 2.1 November 26, 2011 01:35PM |
Re: OptoEndstop 2.1 November 26, 2011 09:33PM |
#if MOTHERBOARD == 33 #define MOTHERBOARD 3 #define RAMPS_V_1_3 #endif
Re: OptoEndstop 2.1 November 27, 2011 03:05AM |
Re: OptoEndstop 2.1 November 27, 2011 06:44AM |
Re: OptoEndstop 2.1 November 29, 2011 02:54AM |
Re: OptoEndstop 2.1 December 05, 2011 12:11PM |
