[Solved] Trouble with RAMPS 1.4 and sprinter, no negative movement
Posted by danieljabailey
March 20, 2012 10:59AM
I have recently killed my Gen6 somehow, there was no hope for it and so I decided to replace it with RAMPS 1.4.
While trying to get the RAMPS to fit the hole left by the Gen6 I had to make a small adapter circuit as unlike the Gen6, RAMPS has no built in opto circuitry.
I have tried to get sprinter to work on it but with no luck. I am at a point where I have the X axis moving but that's it.
The X axis will move as expected with any command telling it to move in the positive direction. (like G1 X50)
Whenever I tell it to move the X axis home (G28 X0) it moves in the positive direction by about ten mm and then stops, if I give the command "G1 X-200" (expecting it to move back to the X endstop) it just stays still.
This sounds exactly like I need to invert my endstops in software, and this is what I did, it didn't help. Same problem when X_ENDSTOP_INVERT is true and when it is false.
How is this possible?
How do I fix it?
Thanks, Dan
Edited 1 time(s). Last edit at 03/26/2012 05:36AM by danieljabailey.
Re: Trouble with RAMPS 1.4 and sprinter, no negative movement
March 22, 2012 02:30PM
I use Marlin firmware, so this may not help.
What does your board return for the "M119" code to get End Stop status?
Does sprinter have a define statment for software endstops like Marlin? I know marlin will not make negative moves if the software endstops are enabled and the value is of an axis reports it is at 0.
March 23, 2012 03:05PM
M119 returns correct values for all endstops.
Disabling software endstops is no help, the problem still occurs.
March 25, 2012 04:03AM
Try inverting the logic of your endstops.
March 25, 2012 05:04AM
dansxmods, to quote my first post:
"This sounds exactly like I need to invert my endstops in software, and this is what I did, it didn't help. Same problem when X_ENDSTOP_INVERT is true and when it is false."
March 25, 2012 05:44AM
I have just tried marlin again. I have it moving on all 3 axes, however, the y axis endstop is showing as high all the time, the LED seems to indicate the status properly even though it is still on when the endstop isn't hit. (the Y endstop LED is very dim when the endstop isn't hit and bright when it is, the X and Z are working fine.) M119 returns correct results so it is unlikely that there is a problem with it.
So now I have the same problem with which I started the thread but on the Y, not the X.
March 26, 2012 05:35AM
Just finished fitting a new mechanical endstop, everything's fine now.
Re: [Solved] Trouble with RAMPS 1.4 and sprinter, no negative movement
March 28, 2012 06:16AM
Sorry about that I somehow missed that in your first post, I am also having probs with my opto endstops now and have just ordered some mechanical ones.
October 08, 2012 11:04AM
I'm getting the same situation.
As i'm uploading my firmware (ErikZalm-Marlin-v1.0.0.RC2-0-g27f595a) the x endstop LED works correctly however once firmware is loaded the LED for the x axis endstop does not go off.
why would the x axis be any different in software, making me think it is a hardware fault.
Any ideas?
Edited 1 time(s). Last edit at 10/08/2012 11:07AM by Gibbedy.
October 08, 2012 05:38PM
Sounds like Marlin configures the endstop to be an output or enables the pullup-resistors or something like that. The difference between the X and Y endstop is the ATmega pin, one of which can be misconfigured.
October 09, 2012 04:02AM
> be misconfigured.
I'm hoping its not a hardware fault with the i/o. I'm having trouble getting sprinter or marlin working in any capacity with pronterface or replicator. This is my first reprap. Using ramps 1.4 ATmega 1280. I believe firmware was loaded correctly using arduino software. Pronterface connects but instantly says something about killing() and I can't move any motors. Away from computer at the moment and can't remember the exact issue. It did say the head was over maximum temperature.
