When I upload a file through pronterface and do a print from SD everything works normally.
However, if I try to print from SD a file I put on the SD card manually just using the OS, the printer behaves totally differently. It moves to the center much slower than usual, then after the first layer z jumps up what looks like a centimeter before continuing to print as normal! How can this happen? Is there a trick to this?
Edited 1 time(s). Last edit at 04/23/2012 12:34AM by unicoder.
