Hi
I have build my own hot end, but I have a problem with the heating. It only heats up to 150 degrees, probably due to too much thermal conductivity.
The hot end uses a 6.8 resistor. I was wonderig if it will get hotter with a lower resistance like 5 Ohm? And can i use such a resistor on the Ramps electronics? Which is the maximum current allowed?
I use an ATX power supply.
Anyone who can answer these questions? Thanks a lot.
