Andrew Smith Wrote:
> That depends on how your Marlin is configured.
> There are two settings for RAMPS1.3+, the normal
> 33 setting puts the fan on D9, the alternate 34
> setting puts a second extruder heater on D9 and
> the fan on D4 which is not connected to anything
> on standard RAMPS. So long as the firmware is set
> to 33, you can use M106 to turn the fan on.
Does this work if the version is 13?
If it is set to 34, can the fan be controlled by an M code?
Edited 1 time(s). Last edit at 08/27/2012 09:29PM by spaceman.
