Hello All! I'm very new to this community/reprap in general.
I've cobbled together my first Prusa Mendel, with parts sourced from various locations (mostly mixshop, with some upgrades such as bearings, couplers, belts, etc from other places).
I've hooked everything up to RAMPS, but the only motor that seems to work perfectly is the y-axis. the x-axis mostly works, but occasionally makes a grinding noise as it moves.. or it'll move fine, then a few moments later you'll hear the motor pulsing even though it looked like it completed movement.. the extruder was working flawlessly, but now also makes a grinding noise for no reason..
I've replaced the Pololu controllers on the z axis which was previously acting really weird, and now that seems 'ok'.. (although i can't seem to get the clamps to actually stay stable on both sides).. I'm thinking the x-axis Pololu controller might be bad as well..
Anyway, I recognize these repraps are labors of love and patience.. but i'm quickly getting to the point where I just want to see it print something :-P.
I will admit I had a lot of trouble making the connectors for the motors to attach to the ramps -- these wires/plugs are really tiny.
so my question is --
Should I just throw out the RAMPS and go with something else more reliable for controlling the motors?
, or is there some place i could send this to, to have them work through troubleshooting this? . I'm located in the Philadelphia area, and willing to drive someplace reasonable with the printer too..
Thanks..
John H
