RAMPS/Arduino T1/T2 pins not working, T0 is okay December 08, 2014 03:03PM |
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay December 08, 2014 04:50PM |
I presume you meant T0 works fine, as that's what's in your subject. If not, I'm confused.Quote
geemoto
However, the T1 pin works just fine and connected the bed thermistor to this port works OK.
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay December 08, 2014 05:08PM |
cdru
geemoto
There are analog pins in Aux-1 and Aux-2 (diagram). You'll need to duplicate the circuit as it appears in the schematic. If you want to know why, read here.
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay December 08, 2014 06:07PM |
No, I meant with the resistor and capacitor. Look at the schematic under the Thermistors section. There's actually 3 duplicate circuits there, one for each thermistor. You''ll need to duplicate one of those with the correct value components in order to get a correct reading.Quote
geemoto
by duplicate the circuit do you mean to simply connect pin 1 to VCC and pin 2 to GND? Or is there more to it then that?
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay December 08, 2014 09:56PM |
cdru
geemoto
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay July 09, 2015 09:48AM |
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay July 10, 2015 06:01AM |
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay July 10, 2015 09:25AM |
o_lampe
How can you kill an analog input?
You must have fed the thermistor pin with negative or >5V source? Did you short the 12V heatbed wire with the thermistor?
-Olaf
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay July 10, 2015 11:00AM |
Re: RAMPS/Arduino T1/T2 pins not working, T0 is okay July 10, 2015 12:00PM |
