LED contol work around help August 20, 2015 10:24PM |
Re: LED contol work around help August 21, 2015 03:13AM |
Re: LED contol work around help August 21, 2015 03:32AM |
o_lampe
I run my Ramps with 13.5V for a few month now, using the same discount LCD without problems.
I don´t know, how this would help getting the bed to 100°C?
-Olaf
Re: LED contol work around help August 26, 2015 04:26AM |
Re: LED contol work around help August 26, 2015 04:45AM |
eatumup
apparently 12v isnt enough to get my heat bed up to temp. So i was concerned that by upping the voltage I would destroy the LCD as I have read warnings to in other posts.
Re: LED contol work around help August 26, 2015 08:24PM |
Re: LED contol work around help August 27, 2015 03:28AM |
Re: LED contol work around help August 27, 2015 09:15AM |
eatumup
Thank you all for the suggestions. I kind of like the idea of an independent psu for the heat bed. Im running a 360w 30A PSU. The heat bed resistance I don't know. Its the one that came with my FoldgerTech 2020 prusa i3. If I did run a seperate Power supply for the bed, could I run it though the same ramps board? Im not really sure how the Ramps passes power from the PSU to just the heat bed or if it passes it along to other systems.
If the 5v regulator was overheated would I lose anything other than the LCD back light?
Re: LED contol work around help August 27, 2015 12:16PM |
xelad
eatumup
You can run it via the RAMPS but you need an external relay, they can be bought fairly cheap. Read this link to understand it a bit more:
[www.youmagine.com]
Note, you don't have to make one, they are available to buy, but read the link to understand what you are trying to do.
