Ramps 1.4 with merlin firmware, z axis homes right with inverted up and down September 17, 2015 10:58AM |
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E3_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing (units are in mm) #define X_MAX_POS 400 #define X_MIN_POS 0 #define Y_MAX_POS 310 #define Y_MIN_POS 0 #define Z_MAX_POS 300 #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
Re: Ramps 1.4 with merlin firmware, z axis homes right with inverted up and down September 17, 2015 04:10PM |
Re: Ramps 1.4 with merlin firmware, z axis homes right with inverted up and down September 17, 2015 08:47PM |
Re: Ramps 1.4 with merlin firmware, z axis homes right with inverted up and down September 18, 2015 07:47AM |
