Can't control fan using Reprap Ramps 1.4 RRD Fan Extender April 11, 2016 12:41PM |
Re: Can't control fan using Reprap Ramps 1.4 RRD Fan Extender April 18, 2016 12:15PM |
Re: Can't control fan using Reprap Ramps 1.4 RRD Fan Extender April 18, 2016 04:36PM |
Re: Can't control fan using Reprap Ramps 1.4 RRD Fan Extender April 19, 2016 07:20AM |
Re: Can't control fan using Reprap Ramps 1.4 RRD Fan Extender April 19, 2016 07:56PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Can't control fan using Reprap Ramps 1.4 RRD Fan Extender April 20, 2016 07:52AM |
Dust
repeated here, since you don't seem to be looking at your other cross posts asking the same thing.
So apparently you have one of these [github.com]
As all earlier board don't have a servo type connectors
D12 and D11 are both PWM pins
M42 P11 S255 and M42 P12 S255 should work
You have wired the expanded correctly? Ie the two pins go to 12v and the 4 pins in a row are for the two fans ?
Update... I see the issue
If you compare the ramps servos pins to the MKS BASE pins you will see gnd and +5v are reversed
ie [reprap.org]
On a ramps the pins for each servo are data pin,+5v and gnd
On the MkS BASE is data pin, gnd then 5v
This board will not work by directly plugging it in to a MKS BASE board
So im guessing whats happening is you have lifted the ground to +5v so the fan is trying to run on 7v (12v - 5v = 7v)
